Author Topic: 4:1 mods?  (Read 771 times)
warriorpoet
  • Solder Ninja
  • Justin
4:1 mods?
« on: November 17, 2017, 11:47:13 PM »
So I accidentally drilled another hole in my enclosure. Now to find a useful mod...
Any suggestions? Fat switch? Bright switch? Crazy oscillating compressor of death by laser beam switch? I'm all ears! :D
Mzo.FX, Owner
WormBoy
  • Solder Ninja
  • TJ
Re: 4:1 mods?
« Reply #1 on: November 18, 2017, 02:45:08 AM »
One thing I always have with compressors is that I feel they dull the sound a little. A small kick in the highs does wonders, to my ears at least. You could easily add some caps on a switch as a bright switch for the comp control, although the boost in brightness will then depend on the setting of comp pot. you could also build in the SWTC2 if you have enough room and willingness to hack: http://www.muzique.com/lab/swtc.htm. Not a spectacular mod, but a useful one  ;D
Boba7
Re: 4:1 mods?
« Reply #2 on: November 18, 2017, 03:20:32 AM »
You could also look for the sensitivity mod that I think Midwayfair came up with, though it'd be quite redundant in my opinion with the mix and depth pot.
I didn't feel that the Afterlife cut highs, but I'm sure there must be some way to add a tone control.
warriorpoet
  • Solder Ninja
  • Justin
Re: 4:1 mods?
« Reply #3 on: November 18, 2017, 11:49:33 AM »
I wonder if there's a way to change the attack or release. I'm not familiar with comp topology, so any suggestions are welcome
Mzo.FX, Owner
