Author Topic: Holy Roller - Verified  (Read 1885 times)
zoof
  • Diode Destroyer
« on: December 11, 2017, 04:48:02 PM »
Works like a charm! Got best result with 1m dark ldr and 5mm red diffused.
  • Administrator
  • Brian
    • madbeanpedals
Re: Holy Roller - Verified
« Reply #1 on: December 11, 2017, 05:51:31 PM »
Great news! What's it like?
zoof
  • Diode Destroyer
« Reply #2 on: December 12, 2017, 10:52:52 AM »
I love it. Built it on vero a couple of weeks ago, this is a little more fun to put in a box though!
Don't know how to describe it, it's there, but not harsh. It does the job it says it will do, it's a limiter :)
Really recommend this.
  • Jason - Evergreen St.
« Reply #3 on: December 12, 2017, 11:04:59 AM »
Seeing a couple points on this schematic that could possibly cause noise issues. Find it any noisier than other compressors?
zoof
  • Diode Destroyer
« Reply #4 on: December 12, 2017, 11:31:34 AM »
Quite the opposite, didn't notice any noise at all. Haven't played it loud yet though.
chordball
  • Solder Ninja
« Reply #5 on: December 12, 2017, 01:09:39 PM »
Can you elaborate? Any ideas for improvements? I haven't built it but it was on my radar.
« Reply #6 on: December 12, 2017, 01:37:22 PM »
Mainly thinking about the LDR on the noninverting opamp input going to a reference voltage. Noninverting inputs have ridiculously high impedance, so that net is extremely sensitive to picking up noise. It's a good idea on layout to keep any traces connecting to a noninverting input absolutely as short as possible.
I've noticed that phasers that use a negative voltage for a split supply rail are much quieter than those with a single rail and reference voltage. If you look at the Mutron Phaser schematic, you see the noninverting inputs and corresponding LDRs are referenced to ground in the phase stages.
chordball
  • Solder Ninja
« Reply #7 on: December 15, 2017, 02:08:32 PM »
Thanks for the explanation. Definitely not something I even considered before so I learned something new. If/when I build this circuit I will play around with the supply scheme.
    • Project Website
« Reply #8 on: December 15, 2017, 08:32:54 PM »
This one has been on the radar for a long time so might have to bust out the FeCl if I can find the pcb's (house is packed up and ready to sell).
Masochist
  • Diode Destroyer
« Reply #9 on: May 16, 2019, 11:48:22 PM »
I know this thread is kind of old but I'm going to be building one of these pretty soon so I just wanted to ask if you mean any LDR with a min 1mOhm dark rating? Sorry I'm pretty new to electronics but keen to learn!
Aristatertotle
  • Stompbox Star
  • Josh
« Reply #10 on: May 17, 2019, 06:08:38 AM »
Probably means something 1 Meg dark, lower resistance light.
http://smallbear-electronics.mybigcommerce.com/photocells-cds-5mm-diameter/ like the 8005 option of these.
Masochist
  • Diode Destroyer
« Reply #11 on: May 21, 2019, 10:34:06 PM »
Thanks mate :)
Masochist
  • Diode Destroyer
« Reply #12 on: June 07, 2019, 01:54:04 AM »
Sorry to hijack this thread again but could someone please illuminate me as to what the 'L' pad is for? It's by itself to the right of the LED +/-.
« Reply #13 on: June 07, 2019, 02:27:15 AM »
Its the "switch" pad for the LED, equivalent to the Grey wire (coming off the LED) in the latter examples in this pdf: http://www.madbeanpedals.com/tutorials/downloads/MBP_FootswitchWiring.pdf
It is the ground path for the LED. When the pedal is "off", the LED is un-grounded, so it doesn't glow. When the pedal is "on", the L pad is switched to ground, so current can flow through the LED and it lights up.
Masochist
  • Diode Destroyer
« Reply #14 on: June 10, 2019, 07:37:09 AM »
Oh ok.. so do I connect the LED + and -, and the L goes to the 3PDT like in the document you linked? Sorry I haven't built a pedal with this kind of configuration before! Plus even though I've built a bunch of pedals I am still a bit of a noob when it comes to electronics! Appreciate your help!!
