Howdy folks,
I'm working on a CS-2 build. Finished populating the board, tossed the pots in, added some flying wires, hooked it up...
And not but silence out the tap. Boo.
So I am now trying to diagnose it. The voltages I'm getting of the OTA match what are listed in the build doc (with one exception, more on that later). Unfortunately I gave away my audio probe (buddy needed a portable guitar amp, and my probe rig was basically that stuffed in an altoids tin), so that will have to wait till I can assemble another one.
However, I noticed something on the schematic, and my limited electrical engineering skills may be failing me slightly.
(since its a bit hard to read: Pin 1 is at the bottom near R8, pin 5 is ground, pin 9 is VA)
So, my question is: Should I get continuity between pins 6 and 7? Because, I am not.
I get 4.4k between pins 2&3. I get 150k between pins 6&4. I get no reading between pins 7&4.
Am I reading the schematic wrong, or is there a fault on the board? Pin 7 is the only pin on the OTA that has a voltage somewhat off from the build doc, so I am wondering.
For reference here is the schematic of the OTA itself:
http://wiki.openmusiclabs.com/wiki/BA662?action=AttachFile&do=view&target=ba662_sch.pngNo connection between pins 6 and 7 there.
