LEDs for DigDug build
Started by mark123, December 19, 2017, 02:36:45 PM
mark123
Is there any reason to not use 5mm LEDs for the DigDug2 build? Will the holes be too close? Is it a concern considering the height of the LEDs?
Just wondering because I have a ton of 5mm LEDs on hand and only a few mixed colors of 3mm.
Regardless, I should use the same color and manufacturer because the FV of the LED affects the CD4017, correct?
mark123
Oh, I see.  It's clearance with the 9mm pots.  Shoot!  I hate to make such a small order.
Quote from: mark123 on December 19, 2017, 02:47:42 PM
I have tons of 3mm what do you need?
mark123
Quote from: flanagan0718 on December 19, 2017, 03:57:20 PMI have tons of 3mm what do you need?
Hey, thanks. I found a few other things for other projects and placed a Tayda order.
Much appreciated though. You're a good fellow.
