Author Topic: Circuit has signal until put into enclosure  (Read 466 times)
kh04453
  • Diode Destroyer
« on: December 21, 2017, 05:11:26 PM »
I built a 2 in 1 (8 Ball, Slow Loris) and the circuits sound great! Problem is, when I put them in the enclosure, I lose signal whenever I turn on a circuit. If I wiggle it around, signal sometimes jumps out for a second but it's never permanent. I know this is a grounding issue but I don't understand what could be grounding out. I've got electrical tape over a lot of the connections to try and shield them.
  • Eric K.
Re: Circuit has signal until put into enclosure
« Reply #1 on: December 21, 2017, 06:03:23 PM »
Could you post some pics?
(I'm resisting the urge to joke about the specific size or paint color of enclosure being the problem.)
In the meantime, what else, besides the enclosure itself, is different?  (Scrutinize every detail).  Did you add even a single solder joint or change even 1 wire?
Not affiliated with Oatey, makers of the world's best and most delicious* low tar solder paste. Ask for Oatey -- It's the juiciest!
*Solder paste is not food.  If ingested, seek medical help promptly.
kh04453
  • Diode Destroyer
« Reply #2 on: December 21, 2017, 07:43:26 PM »
I tried to post a pic but it said the file was too large so I'll post one when I can compress it first. And I followed the build instructions exactly except the two circuits share the power since they're in the same enclosure.
knifedawg
  • Diode Destroyer
« Reply #3 on: December 27, 2017, 10:41:41 AM »
are you using dust covers or electrical tape to keep your pots from grounding out any of the components on the circuit board? that's happened to me a few more times than i'd like to admit. if you're using solder lug pots, i've found that if you're lazy and don't tin your wires first that you can get a poor connection or breakage on a lug.
also double check your 3PDT wiring.  :)
Aleph Null
  • Solder Ninja
    • The Hard Problem
« Reply #4 on: December 28, 2017, 03:54:48 PM »
Bypass signal but no effect signal is almost always a grounding issue. Start by looking for stray wires at connection points like jacks and switches—anything that might ground out on the chasis. Also, if you are using a power supply, the jack must have a plastic barrel. A metal DC jack will ground out on the chasis, resulting in no sound.
  • Jimi Lee
« Reply #5 on: December 28, 2017, 04:05:02 PM »
Sounds to me like one of the 1/4” jacks are grounding out, you get a bad one occasionally.
