Author Topic: Road Rage w/ 4.5V output  (Read 308 times)
cajone5
« on: December 31, 2017, 08:34:48 AM »
Is there a way to modify the road rage to output 9v and 4.5v?  Trying to rehouse a dano pedal and would like to use the road rage to provide the 9v power and a 4.5v power source to replace the switching board...
WormBoy
  • Solder Ninja
  • TJ
Re: Road Rage w/ 4.5V output
« Reply #1 on: December 31, 2017, 09:25:16 AM »
If you only need 9 and 4.5 volts, the road rage is not a very practical place to start from. Just build something on vero with a voltage divider, regulator, or a rail splitter like the TLE2426.
dwhacks
  • Diode Destroyer
« Reply #2 on: January 01, 2018, 01:00:55 PM »
I would use the voltage divider like in your schematic. A TL2426 works good if you need +/- each half of the supply (9v = +4.5, G, -4.5)
You could also use an adjustable regulator (LM317) and calculate the correct resistors (use a trimmer) to get a perfect 4.5v.
cajone5
« Reply #3 on: January 02, 2018, 04:39:39 PM »
I guess I'll just slap a piece of vero in and create the voltage divider shown in the upper right. Should be pretty painless and I could even use it to simplify other stuff (e.g. have it hold the CLR for the LED).
Thanks for the comments... I think I was trying to make it harder than it has to be  :-X
