SMPS Project?
Started by HamSandwich, January 10, 2018, 05:36:02 PM
HamSandwich
Hola,
Are there any SMPS projects out there? I see there's a few posts here and there about them, but no 'here is the schematic, layout, parts lists' etc. I don't expect to find them on a pedal building site, although Grind Custom used to have one I think, but that seems gone. An available PCB isn't critical, but from what I understand, a good layout can make a huge difference in one of these things.
Ideally it could produce 250-300VDC, and maybe enough current to power 3ish 12A#7 tubes? I'm not looking for one to fit in any particular project, but a basic SMPS circuit that could be used in a number of different ideas.
Thanks for your help!
The problem with DIY power supply projects is they tend to be on the dangerous side. Working with mains voltages and current means anyone providing projects to people of unknown skill levels needs to consider "am I liable for what happens to the half brain dead ape like creatures who managed to poke a soldering iron into this thing?"
And really at the end of the day, most DIY projects would end up within ~20% of the price of a commercial option, so there isn't a fantastic motivation on that side as well.
They do exist, but you have to dig a bit, and be very VERY careful with them.
tcpoint
There's some pretty cool modules from China and they're pretty cheap.  I bought one and it's on my todo list.I
HamSandwich
Quote from: somnif on January 10, 2018, 05:57:51 PM
I hear ya man.
That's part of the reason I'm going with SMPS. Wall power and it's scary amps are relegated to 12V or whatever wallwart instead of brought into the confines of a box that connects to me.
I know you have to be safe with an SMPS, just as much wall power and traditional poser transformer. I have built a few amps and am somewhat comfortable with it, but not AS comfortable as an SMPS. Now I sound like I'm convincing myself, don't I?  ;D
I'll keep on digging, thanks!
Quote from: tcpoint on January 10, 2018, 05:59:14 PM
Thanks! I saw those! I am dubious of that kind of stuff mostly from a lack of experience with them. For some reason I trust my hands and eyes more than a chinese fab, which is probably not logical. Ah well.
There are some good online tools available for switch mode power supplies calculations.  Texas Instruments has one and maybe a few other manufacturers.
thomasha
I built a lot of the 12v to 250v SMPS types.
But they don't have that much current available, or get too hot.
For low wattage, like 250v at 20mA, it's OK though. I think maybe a small 12au7 PP would work to.
The kind of inductor is very important, otherwise you end up with a whistle. It must be shielded and also have a small ESR. Same for the caps and the Mosfet. The mosfet can get really hot too, sometimes a heatsink is required so the voltage won't drop after some time. I like to use this schematic>
http://www.desmith.net/NMdS/Electronics/NixiePSU.html
But there are cheaper chips that do the same.
Now something complicated would be one SMPS for the whole amp.
I saw some projects where they used a small flyback transformer to produce the high voltage and the filament supply at the same time, but then it gets big and complicated.
To wind this kind of transformer without the proper equipment is already a nightmare.
In this case it's easier to buy a chinese one on aliexpress.
HamSandwich
Quote from: gtr2 on January 11, 2018, 05:18:32 AM
Thank you, I'll have a look!
Quote from: thomasha on January 11, 2018, 02:05:08 PM
Good info here, thanks!
I've also found some 'NIXIE' supplies on ebay, but some of the inductors look like they may be the danger you mentioned. I'll do some more digging.
Cheers guys!
Some of the nixie power supply circuits on the net have some bad resonance as mentioned.  Proceed with caution, even though it's still low current, for instance 20mA at 170-220VDC, it can still kill you in the right circumstance.
You can also get some ringing from MLCCs.
Josh
HamSandwich
Thanks, Josh! Warnings heeded.
The more I dig the more doing a 12VAC 24W wallwart into the secondaries of a 12V 25W transformer with the primary at 240V seems like an easier, or at least more understandable, and perhaps stable(?) way of doing it. Price and size being the only apparent detractors. Now it's time to learn about fuses  :'(
tcpoint
Or you can use some space charge tubes (low voltage tubes made for automobile radios).  They were pretty cheap, last I looked.  Or the Korg nutube is a low voltage - power efficient tube.  It's manufactured by a fluorescent bulb maker in Japan.  They are pretty pricey at $50 a dual triode.  You can also use a 12.6vac and use a voltage multiplier to get medium voltages  (you can do a search on a cavalli SOHA headphone amplifier or a CTH headphone amplifier for some examples.
WormBoy
Tube Town in Germany has a kit for a module that turns 12V into max. 220V @15mA: https://www.tube-town.net/ttstore/Kits/Power-Supply/TT-VPump-Voltage-Converter::6163.html. I built one of these, and it works, but I still need to build a pre-amp with it, so it is not tested by me in practice yet (not sure if that would be a real recommendation anyway  ;D).
HamSandwich
Thanks guys! I've ended up just going with a reverse transformer and wallwart. Plenty of amps, cheap and less likely to have noise issues! Thanks for all the responses.
thomasha
So, if someone is looking for some info about how the layout plays an important role in SMPS circuits, yesterday I found this page:
https://www.powerelectronicsnews.com/problems-solutions/pcb-layout-for-emc-power-supply-design-tutorial-section-3-1
Helped me a lot in identifying some of my own mistakes in one of my SMPS. I was getting an anoying ringing where in a previous attempt there was none. Turns out my return path for the mosfet was a big loop.
Willybomb
Juan pointed me to this on his page.  I've built it, but I must have done something wrong as I'm only getting 130v out of it, with very, very, little variation from the trimmer.  As noted on his page, you can't substitute anything or it doesn't work right (I haven't so it's user error right now).  I hope this is what you're looking for.
