Aion Refractor Help
Started by Big Mike 1100, January 27, 2018, 10:14:50 AM
Big Mike 1100
I put together an Aion Refractor.  The mods I made (based on what I had were-
-I initially socketed the diodes, but thought they were faulty so I soldered them in
-I believe I changed C14 to a 6n8
I initially thought maybe I had a broken gain pot, so although the pic has a B500K dual gain pot pictured, I swapped it out for two 250KB single pots with the same results as below
https://aionelectronics.com/project/refractor-centaur-overdrive/
IC1 (LF353P)
1-   6.73
2-   6.73
3-   5.79
4-   0
5-   6.7
6-   6.69
7-   5.94
8-   9.36
IC2 (LF353P)
1-   8.24
2-   6.88
3-   6.73
4-   7.27
5-   6.74
6-   6.98
7-   8.25
8-   8.86
IC3- TC1044SPCA
1-   9.36
2-   9.36
3-   8.4 (fluxuates 8.4-8.1 up and down)
4-   7.28
5-   7.28
6-   7.93
7-   7.93
8-   9.36
I tried measuring D1, D2, D3 and D4, but not sure if I'm testing correctly.  Sometimes they read 0 and other times they read -3 or -2.93
Regarding the sound- when the pedal is not turned on, there is clear working signal.  When the pedal is engaged, the light turns on and there is clear guitar sound, but its noticeably quieter than the bypassed volume and there is no gain whatsoever.  The volume pot works as it should but neither the tone nor dual gain pots (or the two single 250kB pots swapped) work at all.
sonnyboy27
You should be getting a higher voltage on one of your ICs due to the charge pump. You should also be getting at least one -9V on an IC somewhere from the charge pump as well.
Big Mike 1100
Thanks Sonnyboy.  I rechecked and got the same measurements- no  -9V anywhere.  Besides a solder bridge near the IC3 (charge pump)  is there something else I can test for?
sonnyboy27
Check to make sure that the back of the gain pot isn't grounding out the board. I put a piece of a business card between the pot and the the board to do that. I imagine that might be your problem.
