Author Topic: Triumvirate  (Read 919 times)
Droogie
  • Electron Doctor
  • Andrew
    • View Profile
Triumvirate
« on: February 12, 2018, 10:22:25 AM »
Built up the Triumvirate distortion over the weekend, and fired right up. This thing is loud. I like the idea of being able to emphasize both volume and gain of each band, and I got a good sound with all 57  :)  internal trims in the middle. It went straight on my board for a gig tomorrow night, but I'm curious to tweak and see what else is revealed.  Built in a 1590BS with bottom mounted jacks (to sit on the top row of my board).
Do the treble mod as indicated in the build doc—it has way too much as is, and was squealing a bit while testing—cleared up once I boxed it up. Well worth building if you own stock in Bournes!
Chief Executive Officer in Charge of Burrito Redistribution at Hytone Electric
blearyeyes
  • Electron Doctor
  • Like so many others, my name is Dan.
    • View Profile
Re: Triumvirate
« Reply #1 on: February 12, 2018, 07:12:16 PM »
I have to built mine!
I sometimes build pedals as "Dan"
I built peddles for Bat Thumb’s car.
  • Electron Doctor
  • Eric K.
    • View Profile
Re: Triumvirate
« Reply #2 on: February 12, 2018, 07:27:29 PM »
Is that a candy red finish?
Not affiliated with Oatey, makers of the world's best and most delicious* low tar solder paste. Ask for Oatey -- It's the juiciest!
*Solder paste is not food.  If ingested, seek medical help promptly.
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
Re: Triumvirate
« Reply #3 on: February 12, 2018, 07:55:34 PM »
Bottom mounted jacks? You maniac!
Looks good. Glad you did the treble mod.
I own madbeanpedals (duh). I am part owner of Function F(X).
Droogie
  • Electron Doctor
  • Andrew
    • View Profile
Re: Triumvirate
« Reply #4 on: February 12, 2018, 09:43:07 PM »
It's that or use ludicrously long cables to connect to the looper!
[/quote]
Oh yeah!
  • Electron Doctor
    • View Profile
    • Project Website
Re: Triumvirate
« Reply #5 on: February 12, 2018, 09:51:19 PM »
Hmmm, that's a really cool idea for a board with a controller!
I'm just finishing up my tri now. First time I've had to buy trimmers by the skid...
  • Electron Doctor
  • Eric K.
    • View Profile
Re: Triumvirate
« Reply #6 on: February 12, 2018, 11:24:12 PM »
That stomp switch looks different....
Is it just the angle and lighting, or is there a cap on it?  A dress nut too?
LaceSensor
  • Electron Doctor
  • Lovetone 4 Ever
    • View Profile
    • How Not To Make A Pedal
Re: Triumvirate
« Reply #7 on: February 13, 2018, 04:30:53 AM »
marvelling also at the number of trimmers lol
Droogie
  • Electron Doctor
  • Andrew
    • View Profile
Re: Triumvirate
« Reply #8 on: February 13, 2018, 09:47:58 AM »
Bog standard, just the lighting I guess.
sonnyboy27
  • Solder Ninja
  • Stephen
    • View Profile
    • Prentiss Effects DIY Blog
Re: Triumvirate
« Reply #9 on: February 13, 2018, 10:44:03 AM »
The bottom mounted jacks are a really cool idea. If I had a looper I'd definitely be stealing that idea from you.
fair.child
  • Electron Doctor
    • View Profile
Re: Triumvirate
« Reply #10 on: February 14, 2018, 01:46:55 PM »
How did you frequency bias the trimpots?
Droogie
  • Electron Doctor
  • Andrew
    • View Profile
Re: Triumvirate
« Reply #11 on: February 15, 2018, 09:20:02 AM »
I set everything in the middle just to fire it up to use on a gig. The great thing about adjusting the gain and volume individually for each band is that you can dial out anything that doesn't work for you. I'm pretty much Captain Midrange when it comes to overdrive and distortion, so it didn't matter where the treble was set, and I still got a sound I was happy with. I plan on doing some trimmer tweaking this weekend to see what happens.
fair.child
  • Electron Doctor
    • View Profile
Re: Triumvirate
« Reply #12 on: February 15, 2018, 10:37:19 PM »
Is there anyway we can bias the 8 trimpots to the stock Triumvirate?
I am aiming for these
LOW,LOW MID = 290Hz. HIGH MID=1.6kHz and HIGH=1.35 kHz
Also how to bias the PRE and CUT?
