Author Topic: Any reasons not to use a colour laser printer for enclosure artwork  (Read 1998 times)
Philtre
  • Stompbox Star
  • Phil - UK
It seems that an Inkjet printer is the preferred type of printer to create artwork for enclosures. Either on water-slide decal paper or sticky vinyl paper. Then cover with Envirotex or clear coat.
But why not use a colour laser printer on white sticky back paper such as this https://www.amazon.co.uk/Sheets-Quality-Adhesive-Sticky-Printing/dp/B00W2E5N36 and then cover?
Is perhaps the colour not so vivid? Other reasons?
Adam_MD
  • Solder Ninja
  • Colin
Re: Any reasons not to use a colour laser printer for enclosure artwork
« Reply #1 on: March 28, 2018, 05:22:03 AM »
I think itís more that colour inkjet are cheaper to buy and most people already have an inkjet printer.
Philtre
  • Stompbox Star
  • Phil - UK
« Reply #2 on: March 28, 2018, 05:26:39 AM »
Colin, I'm thinking about getting a colour laser printer because of the high cost of replacement ink cartridges.
I just bought a Canon ip7250 for £50. The Canon ink cartridges are about £40. When the ink runs out, I could sell the printer for £10 then buy a new one for £50 giving me a brand new printer and replacement cartridges each time!
  • Jimi Lee
« Reply #3 on: March 28, 2018, 06:49:28 AM »
I use a laser printer. The cartridges are more expensive, but so far have lasted 3x longer, Iím still using the ones that it came with.
Adam_MD
  • Solder Ninja
  • Colin
« Reply #4 on: March 28, 2018, 06:52:07 AM »
I have the same printer Phil and have been using these for over a year with no problems.  You get 4 replacements for each colour in this pack for £12.99.
https://www.amazon.co.uk/gp/product/B00K2XU6FE/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Philtre
  • Stompbox Star
  • Phil - UK
« Reply #5 on: March 28, 2018, 07:02:50 AM »
Wow, that's a bargain. Do you think the colour is in any way inferior to Canon ink?
Philtre
  • Stompbox Star
  • Phil - UK
« Reply #6 on: March 28, 2018, 07:03:49 AM »
What type of paper do you use, Jimi? I'm thinking of sticky back stuff for enclosures.
  • Jimi Lee
« Reply #7 on: March 28, 2018, 07:32:03 AM »
I use water slide decals. I like the white as opposed to the clear, the colors are more vibrant. I get it off of eBay, as itís nearly impossible to find around here. Sticky back is ok, but you only get one shot at putting it on.
  • Function f(x)
« Reply #8 on: March 28, 2018, 07:34:24 AM »
I've used laserjet toner on "fancy" (bonded) paper and then put on a coat of Mod Podge to seal. You can then spray acrylic clear over that if you want to go a step further. Here's an example:
Philtre
  • Stompbox Star
  • Phil - UK
« Reply #9 on: March 28, 2018, 07:36:01 AM »
And I guess you don't need to coat it before putting it in the water?
  • Jimi Lee
« Reply #10 on: March 28, 2018, 07:36:56 AM »
Nope, no need to, that was one of the attractions for me.
Philtre
  • Stompbox Star
  • Phil - UK
« Reply #11 on: March 28, 2018, 07:44:06 AM »
How adhesive is a water slide decal? If it's covered with Envirotex the whole lot has to be stuck to the enclosure by whatever's on the back of the decal paper.
  • Jimi Lee
« Reply #12 on: March 28, 2018, 07:47:42 AM »
It sticks pretty good once itís dried after about 8 hours. I think thatís the key, I rushed one once and the decal floated up on the edges. Iíve done a couple hundred pedals this way, itís just trial and error.
Adam_MD
  • Solder Ninja
  • Colin
« Reply #13 on: March 28, 2018, 09:14:49 AM »
No itís been absolutely fine.  The decals on most of the pedals youíve seen me post have been printed with it.
Philtre
  • Stompbox Star
  • Phil - UK
« Reply #14 on: March 28, 2018, 12:05:05 PM »
I wonder if it would be possible to print on shiny or satin paper with a colour laser printer and then just glue it to the top of the enclosure? Does the laser ink need to be protected with a clear coat or some kind of lacquer? (I'm looking for simpler alternatives to Envirotex or spraying clear coat on decals).
