Author Topic: Blueprint tap tempo  (Read 1263 times)
Aentons
  • Stompbox Star
Re: Blueprint tap tempo
« Reply #15 on: May 02, 2018, 08:01:05 PM »
Strange, took it out of the case and it works fine. Works fine back in the case now too. Oh well
« Last Edit: May 02, 2018, 09:09:20 PM by Aentons »
Aentons
  • Stompbox Star
« Reply #16 on: June 17, 2018, 10:09:21 AM »
I've been looking at the Blueprint schematic.
I see that the X1 connectors are the row at the top of the board for connecting the tap tempo daughter board, and X2 is the 10k resistor network.
« Last Edit: June 22, 2018, 07:28:08 PM by Aentons »
fair.child
« Reply #17 on: June 21, 2018, 11:25:11 PM »
For those who want to build Blueprint with tap tempo, here's the configuration:
I have spent days and night to figure about it. Peter helped me out with the wiring.
Here's the guideline:
1. Build the Blueprint, follow MBP Build Doc
2. Leave the JUMP open and jumper the TAP. I'd suggest to get 0 Ohm resistor and put it on the back in case you don't like it and wanted to switch to normal. For my Blueprint, I do socket those resistors so it's easier for me to debug. It's recommended but the PT2399 will be a tight fit. Watch out while you're soldering.
3. Get the Tap Tempo board from UK Electronics.
Kit Tap Tempo V2-TA for Digital Delay PT-80 *This is what I have
[130-095]
https://www.uk-electronic.de/onlineshop/product_info.php?products_id=3099
OR
Kit Tap Tempo V2for Digital Delay PT-80 *This is what VFE Blueprint has
[130-094]
https://www.uk-electronic.de/onlineshop/product_info.php?products_id=1797
4. Populate the Tap Tempo and wire the tap tempo board to Blueprint board. Follow the picture above.
5. Test it out and hopefully, it works!
zgrav
  • Transistor Tickler
« Reply #18 on: June 22, 2018, 06:32:25 AM »
thanks for sharing that info.  I have built the Blueprint and may try this mod.
