Author Topic: Valvecaster a値a sci-fi  (Read 1277 times)
Tom Lauten
  • Diode Destroyer
« on: June 27, 2018, 02:40:26 PM »
This is my Decopunk/Atompunk style Valvecaster pedal.
I love the sound of an overdriven tube amp but I also love the convenience of a battery powered, solid state amp. What to do? Enter Matsumin Valvecaster. This is a simple, low voltage pedal that drives a 12AU7 tube to pretty convincing overdrive.
I like the retro feel of tubes and I thought this clever and rich pedal circuit needed a stylish home in keeping with the feel of its main component.
I spotted 2 vintage Weston electrical meters online and the idea hit me, mount the valve externally and make a show of it. I took cues from the shape of the upper plinth and the meters viewing window and after some careful measuring of the tube, socket and meters body I made a template and cut 6 cooling fins from 2mm aluminium. After further measuring I drilled the tube hole and mounting points. I used 5mm hex stand offs between each fin. After a lot of sanding and finishing the radiator was done.
I removed all of the meters guts and external fittings and drilled where I needed to for the power input (no room for an internal battery) and pilot light ( a fender amp jewel light with a led imbedded in it with translucent silicone for diffusion. The Valvecaster has 3 controls, volume, tone and gain. The meter had 4 terminals so I fitted a 4th pot that switches on and can set the brightness of a 3mm led that illuminates the tube from below emulating a tubes glow. I drilled out the meters original brass terminal screws and used them as control knobs.
The input and output jacks fit amazingly well owing to the efficient and space saving point to point wiring of the circuits components onto the valve socket itself. I used a daughter board on the foot switch which makes true bypass, ground connections and hook ups a cinch.
And there we have it, a real tube based, Machine age style overdrive emulator pedal...as used by The Rocketeer!
« Last Edit: June 27, 2018, 02:43:08 PM by Tom Lauten »
Marshall Arts
Re: Valvecaster a値a sci-fi
« Reply #1 on: June 27, 2018, 02:45:46 PM »
Holy! Taking it serious, aren't you? Probably the most awesome and unique pedal I've seen so far...
Tom Lauten
  • Diode Destroyer
« Reply #2 on: June 27, 2018, 03:07:17 PM »
Lol...thanks! Sometimes I gotta 堵o big or go home! My business is special effects so my prop making hat goes on.
Torgoslayer
  • Solder Ninja
« Reply #3 on: June 27, 2018, 03:12:30 PM »
That is very pretty. I'm in awe!
Gnarcade
  • Diode Destroyer
« Reply #4 on: June 27, 2018, 03:26:05 PM »
This is gorgeous! Looks like something straight out of one of the "Fallout" games!
Tom Lauten
  • Diode Destroyer
« Reply #5 on: June 27, 2018, 03:28:25 PM »
Thanks folks!
  • Stephan Nelson / New Zealand / Aotearoa
« Reply #6 on: June 27, 2018, 03:34:41 PM »
Fabulous! Style, looks, all the story behind it recycling that meter... effin' awesome!
  • Matt
    • My pedal blog
« Reply #7 on: June 27, 2018, 04:22:32 PM »
Wow, that's beautiful.  I really like the cooling fins.
Black Napkins
  • Diode Destroyer
  • Matt
« Reply #8 on: June 27, 2018, 08:52:09 PM »
Absolutely fantastic! Very unique morphing with outstanding 'almost Steam Punk' ingenuity. Looks a treat. :)
  • Jason - Evergreen St.
« Reply #9 on: June 27, 2018, 09:19:51 PM »
I'm wowed, sir. Wowed.
Tom Lauten
  • Diode Destroyer
« Reply #10 on: June 28, 2018, 01:36:20 AM »
Thanks very much everyone!
storyboardist
  • Stompbox Star
  • David - Woodstock, GA
    • Perf & PCB Layouts
« Reply #11 on: June 28, 2018, 07:57:20 AM »
+1 That looks incredible!
Guy behind Effects Layouts
Tom Lauten
  • Diode Destroyer
« Reply #12 on: June 28, 2018, 08:19:28 AM »
Thanks again, just did some basic decals...I値l post some shots later.
Tom Lauten
  • Diode Destroyer
« Reply #13 on: June 28, 2018, 01:23:31 PM »
And with the graphics....
blearyeyes
  • Like so many others, my name is Dan.
« Reply #14 on: June 28, 2018, 03:44:45 PM »
That is spectacular! Nothing else like it so 1st place for originality!
That is really FUN!
I sometimes build pedals as "Dan"
I built peddles for Bat Thumb痴 car.
