Author Topic: Autobahn aka MP Snow White autowah (Troubleshooting)  (Read 305 times)
brainbender
  • Diode Destroyer
« on: August 11, 2018, 03:51:43 PM »
Hi!
I'm having trouble with Autobahn. When I put a 78L05 in it's place, pedal sounds thin and have a pronounced envelope and high quack. Without it it seems to work ok (but just OK :D), but it has a high volume boost and it seems it triggers somewhat strange. I checked the tripple checked the values of components, checked for bad solder joints and shorts with USB microscope and everything is good. Also, i swapped more then 10 78L05's and replaced the IC's with other, but nothing is changing.
Any sugestions? Thanks! :)
  • Jimi Lee
« Reply #1 on: August 11, 2018, 04:15:04 PM »
Clear, up close pictures both sides of the board and off board wiring. Also, do you remember the jumpers?
brainbender
  • Diode Destroyer
Re: Autobahn aka MP Snow White autowah (Troubleshooting)
« Reply #2 on: August 11, 2018, 04:29:16 PM »
My phone camera broke, so I can't post any photos. Everything with pcb is good, just as components. Weird... I can post some audio tomorrow. Offboard wiring is as always, Brian's method.
Btw. it sounds more like EHX Bassballs if that helps. :)
« Last Edit: August 11, 2018, 04:33:50 PM by brainbender »
