Author Topic: Double Flush Depth  (Read 518 times)
DLW
  • Stompbox Star
Double Flush Depth
« on: August 20, 2018, 08:34:21 AM »
I recently etched and assembled a Double Flush. Everything seems to be functioning properly with one notable exception... The 'Depth" pot is very weak. There is an audible tremolo effect only at max CW of the Depth pot. I've tried several vactrol combinations and ~10 different pots ranging from B10k to B1M. None of these changes affected (for better or worse) the tremolo effect.
Another strange thing is the board mounted rate LED intensity is inversely proportional to the vactrol LED, meaning when I crank the Depth knob, the rate LED dims and the vactrol LED gets slightly brighter. This doesn't bother me at all. I'm just wondering if this is a symptom related to the above problem.
Has anybody experienced anything like this? Are there particular components that I could replace to boost the Depth control?
Thanks!
Darin
stringsthings
Re: Double Flush Depth
« Reply #1 on: August 20, 2018, 06:49:01 PM »
Hey Darin,
Can you post voltages on the IC pins?  That will help in the trouble-shooting.
strings
All You Need Is Love
DLW
  • Stompbox Star
« Reply #2 on: August 20, 2018, 09:01:44 PM »
Thanks for the reply, Strings. I was fumbling around (pots kept falling out) trying to measure the IC voltages and noticed that the LM351 was backwards. I swapped it around, and everything works flawlessly now :)
