MBP 1590G Clean and ROCK Demo
Started by jjjimi84, August 20, 2018, 02:34:54 PM
Here is two tracks showcasing the incredible 1590G pedals, I wanted to show the subtly of the effects with a clean demo and then how great they are for rock.
[soundcloud]https://soundcloud.com/dan-keclik/mbp-1590g-clean-demo[/soundcloud]
This track was recorded with a strat into a Mesa TA-30 on the clean channel into a Two Notes Torpedo Live with a Celestion Blue IR. The signal path was 4:1 Compressor into the Moar into the amp with the Mimik in the effects loop. There is three guitars on here, the main rhythm which is using just compression and a little delay, and then the first solo where i turn up the delay and compression, once the second lead guitar part comes in i stomp on the moar.
[soundcloud]https://soundcloud.com/dan-keclik/mbp-1590g-rock-demo[/soundcloud]
This track was recorded using a Gibson SG with Lindy Fralin 90s into the Mesa TA-30 on channel two into the Two Notes with a 4x12 cab loaded. On the right side is the moar on the left is the stank and for the solo I ran the compressor into the moar into the mimik into the front of the amp. Also there is a little delay on the left side during some of the bridge area.
As for how this was made I wrote the drums and then just layer on top, only plugins are ezdrummer and mix buss compression, here it is warts and all sort of thing.
I am thinking about putting out the tracks with out my shitty lead playing so others can riff on them if anyone is interested.
From Left to right Mimik, Stank, Moar, 4:1
The mighty SG!
