Author Topic: Slow loris  (Read 601 times)
Bandersnatch
  • Diode Destroyer
Slow loris
« on: September 10, 2018, 02:43:39 PM »
I just finished it everything works as it should. I bought a light plate for it. I was thinking of using the cliping leds (D1 D2) for the light plate. I want to add more light but don't know if it will effect the sound? Is two leds enuf light for the plate? I have 2 3mm leds now. I don't want to drill and glue leds until I know. Thanks in advance.
"To defy the laws of tradition is a crusade only of the brave"
Les.
  • Administrator
  • Brian
    • madbeanpedals
Re: Slow loris
« Reply #1 on: September 10, 2018, 02:50:33 PM »
Adding more LEDs will definitely change the clipping some. The two might be enough...I don't have any experience with light plates, though.
Bandersnatch
  • Diode Destroyer
Re: Slow loris
« Reply #2 on: September 10, 2018, 05:35:17 PM »
Thank you. Hopefully someone with light plate experience will chime in. What about changing size of leds? They are 3mm now what if I went to 5mm or 8mm high bright clear?
Les.
  • Administrator
  • Brian
    • madbeanpedals
Re: Slow loris
« Reply #3 on: September 10, 2018, 05:36:46 PM »
5mm would be fine. Again, changing the LED type or color will change the clipping. Maybe not in a bad way but it's the kind of thing where you'd have to compare to see if you like it or not.
Bandersnatch
  • Diode Destroyer
Re: Slow loris
« Reply #4 on: September 10, 2018, 07:50:59 PM »
Ok I am going to mess around with them. Thanks again for your help. I will be posting a build report as soon as it is done.
Les.
chromesphere
  • Paul
    • Chromesphere
Re: Slow loris
« Reply #5 on: September 11, 2018, 12:07:13 AM »
I have made light plates with 2 leds (my profile picture), its 'enough' to see the pedal is on.  But this is using bypass leds, not clippers.  I have a feeling 2 x 3mm as clippers will be hard to notice in a light plate.
Pedal Parts Shop            Youtube
Bandersnatch
  • Diode Destroyer
Re: Slow loris
« Reply #6 on: September 11, 2018, 10:24:32 PM »
I ordered 2 8mm high bright clear red. I am going to see how much it changes the sound.
Les.
