Author Topic: TOTAL RECALL - very low voltages on all ICs  (Read 1132 times)
Re: TOTAL RECALL - very low voltages on all ICs
« Reply #15 on: November 17, 2019, 04:51:11 PM »
Found a bridge, which is going to be impossible to fix. Itís on IC8 and am not eve sure it was causing the problem, as pins 4, 5, and 6 were shorted somehow. But after removing the socket and all the solder, they keep shorted. I was wondering if this could be a board defect. In any case Iíll need another one if I want to continue with this project...the current is not usable anymore... have a look to its state...
That wasn't your problem, 4, 5, and 6 (as well as 14) are tied together to ground, as per the schematic.
More likely you had a short to ground somewhere on the power rail. Was anything making contact with the backs of the potentiometers?
Zoot
  • Diode Destroyer
« Reply #16 on: November 18, 2019, 12:36:35 AM »
I see, still learning this thing... I controlled the power rail n times, couldnít find anything that was sucking all the power...
