A Quiet Place
Started by pickdropper, October 01, 2018, 09:09:17 PM
Quote from: jubal81 on October 02, 2018, 12:11:46 PM
And it doesn't even look cramped....Pretty doggone slick.
Looking at it, though, wondering if you'd considered just putting the footswitch on the main PCB - looks about the same height. Then maybe mounting the pots to a second PCB with a ribbon connector.
I generally avoid putting the footswitch on the main PCB, especially with such a long cantilever like this.  It a safer bet to wire it off board.  Admittedly a conservative approach, but the wiring wasn't too bad on this one.
diablochris6
Holy guacamole. That has to be Howard Hughes-level of cleanliness and perfection in that PCB design. Epic build.
Thanks for the kind words, folks.  This build was definitely a bit on the OCD side, but I had a lot of fun with it.
Martan
Just wow. Very impressive all around.
BryGuy
My 46th birthday is a couple months away and I know what you can get me!
Seriously, that is pretty outstanding.
Perfection aside, that is just a beautiful object.
... and then there's the perfection. There's that too. How does the silence sound?
I think you've officially outed yourself as a robot.
Impressive sir, most impressive.  8)
