Author Topic: Eoo3: Programmable Looper/Switcher/Midi Controller  (Read 7901 times)
Marshall Arts
« on: November 01, 2018, 02:54:30 PM »
This is basically an arduino looper for eight loops with the ability to store 12 presets. It can also be used to switch up to 4 amp functions (required for my Engl Ironball). For another amp (Marshall 2554), I needed an additional switch to change the polarity of one of the switches (so the LED is lit, if the hot channel of that amp is activated).
Anyway, I built it already in 2015, resurrected it today from the basement and shockingly found out that I never labelled it, so I had to reverse engineer what the 6 mini switches, 17 footswitches and 14 jacks were for. So, the only reasons to post it now is twofold:
  • I think, it got lost in a forum crash years ago.
  • Remember to label in time, if you ever build something that big.
Eye-candy:
...and the way it looks today:
« Last Edit: March 10, 2019, 10:05:17 AM by Marshall Arts »
brejna
  • Brane
    • aestheticempathy
Re: Programmable Arduino Looper / Switcher
« Reply #1 on: November 01, 2018, 03:23:10 PM »
Ahahahaha! Awesome! I am looking at the pcbs I got from you and I was thinking there is no way will finish this.. And you post it right now.. :D
Marshall Arts
« Reply #2 on: November 01, 2018, 03:46:10 PM »
Brenja ! At least I can say that it works perfectly even yrs after building it. Like your voodoo vibe...
    • Project Website
« Reply #3 on: November 01, 2018, 05:32:51 PM »
Mine's about 90% done.  Hopefully this pushes me to finish it.
  • Administrator
  • Brian
    • madbeanpedals
« Reply #4 on: November 01, 2018, 05:58:15 PM »
Damn, I need this in my life :)
  • Stompbox Star
« Reply #5 on: November 01, 2018, 06:57:40 PM »
Yep that is amazing!
« Reply #6 on: November 01, 2018, 07:47:47 PM »
Me too.  What a fantastic job.
  • Stephan Nelson / New Zealand / Aotearoa
« Reply #7 on: November 02, 2018, 12:08:57 AM »
Totally amazeballs!  :o
brejna
  • Brane
    • aestheticempathy
« Reply #8 on: November 02, 2018, 01:49:16 AM »
This is great project.. Is this suppose to be 14 preset looper?
Poslano sa mog Redmi Note 6 Pro koristeći Tapatalk
Marshall Arts
« Reply #9 on: November 02, 2018, 01:52:11 AM »
Yes, it can do 14 presets, but on mine, I sacrificed one button, so MINE is 12 presets only. Will use the lower left button for a taprecise board.
brejna
  • Brane
    • aestheticempathy
« Reply #10 on: November 02, 2018, 01:56:02 AM »
I get it.. I will probably start working on it. Only thing I cannot decide what do with is enclosure..
P.S. Probably everyone are expecting another run of pcbs and chips.. :)
Marshall Arts
« Reply #11 on: November 02, 2018, 02:05:20 AM »
You should get the blocan enclosure, it's worth it. Check the build doc for details...
I would create a new version of the relay board, if I ever find time. I made it with fritzing (!), meanwhile I know how to work with eagle. Fix some minor issues, but God knows when I find time...
Marshall Arts
« Reply #12 on: November 02, 2018, 02:13:13 AM »
For the enclosure:
http://www.rk-rose-
krieger.com/fileadmin/catalogue/neuheiten/news_kabelkanalsystem_gb.pdf
brejna
  • Brane
    • aestheticempathy
« Reply #13 on: November 02, 2018, 02:13:31 AM »
Your build is in 80cm long enclosure, right?
Whenever you find time to make another batch, count me in..
Marshall Arts
« Reply #14 on: November 02, 2018, 07:23:49 AM »
It's actually 60.5 mm long. I will see, if I find the time for a new release. Changes would be:
- Relay board:
-- Move Cable connections to the side of the board, that points toward the inside of the enclosure
-- Create an eagle component, that allows for easy shielded wire connection (basically a hole to push the cable through, with a solder pad for the shield and another solder pad next to that for the inner wire)
-- Correct missing ground connections (result of a bug in fritzing)
-- Improve ground plane (Version 1 has ground fill, but eagle can do this much better than fritzing)
- Control board:
-- Add space for blocking caps
-- change design to load a complete nano (like I have done on my moebius controller and my taprecise design) - they are dead cheap these days and come with an USB port, so people can program their own software, update easily etc. Plus, I dont have to program and ship them.
-- use internal pullup resistors in the Atmel processor (and get rid of the 17 10k resistors) - this requires inversion of the switch logic in the program code, though...
-- Add a Midi-Port. It's not hard to do in Arduino to send out static Midi program changes on events. And I might want to add a Line6 HX Stomp to my board somewhen in the near future...
Other:
- Change drill template, so the jacks are more far away from the relays
- Add little board for footswitches and LED
- Add a solid-state-relay based mute function (mute the output for 10 ms while switching)
- Add a third bank and a tri-color-LED for a total of 21 presets
- Skip the "Write" button. Store presets by holding respective program button down for three seconds. Downside: Program change will happen on the release of a button (because only then the system will know, that the button has not been pressed long). Alternative: Enter write mode by holding down the bank switch for three seconds.
- Add an input buffer
- Enhance one or two loops with a "trails" feature (for delays or reverbs), with phase invert option.
- Add a Tuner out/Mute button
- Bypassable, galvanic separation of Loop 7 or 8 for use with two amps
- Move Jacks for Input, send, return and output to the (audio) side of the looper (adjust the audio PCB accordingly). Depending on how you build it, this could be either left or right. Potentially reduces the need for an additional patchbay on the board.
- Mute on Tap Tempo Longpress
- external access to usb port
I should mention, that none of these is crucial and that version 1 works very well.
« Last Edit: November 26, 2018, 04:42:08 AM by Marshall Arts »
