moodring build!
Started by ChRa, November 27, 2018, 06:31:20 AM
ChRa
I just completed the Moodring. What a cool pedal! I was worried because the components are tightly spaced and there is almost no room in the box for error. Thanks to Brian's awesome photoshop drill templates (...why don't all PCB sellers do that?), however, I nailed it with no errors. If you knew my record with boxing pedals you'd be as amazed as I am.
Thanks Brian!
ChRa
BTW, the center is black because I had to rig wires from the transistor socket to a separate board for the smd J201. The black is some heat shrink that I slipped over the board to prevent shorts.
