Marshall JackHammer
Started by rjkanejr, October 17, 2011, 02:11:29 PM
rjkanejr
Anyone know what the Marshall JackHammer is schematic-wise - anyone have a schematic?  It looks like it may be a TS clone (or clone of the Boss HM-2).  It has a OD/Dist selector which if I were to guess switches between either soft clipping/hard clipping, i.e. diodes and LEDs for the clipping section?  I ask all this as a friend just obtained one of these and used it in front of a Carvin Vintage tube amp and the clarity of the overdrive was very nice, could distinguish all notes in a chord played while it had sweet singing sustain for solos.  Impressive pedal actually.  Anyone have any info about this pedal, a schematic to make one, what the MadBean equivalent may be?  Anyone?  Anyone?
irmcdermott
rjkanejr
Thanks for the schematic.  So.... can anyone explain it?   :o  I am not the sharpest tool in the pedal builder workshop!  It looks like it uses 3 TL072 ICs, is that correct?  So with 3 ICs this isn't exaclty a TS clone?  It also appears my guess is right that the OD/DIST toggles between LEDs and diodes for the clipping section.
Sounds like you have a basic understanding of it.
I had this pedal for a long time. You can find them used for less than $50, it's not really worth building I don't think.
The plexitone is where it's at for the same sort of tone.
