Author Topic: Releases pushed back to Jan 14th  (Read 2052 times)
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
« on: January 04, 2019, 06:45:23 PM »
I'm moving the next release date back one week to give myself a bit more time. I'm having to do verification builds on the Harbinger Two and Glitchee since there were some changes made after the prototype plus I need to box and do demos of the three new projects. The changes have been verified via breadboard but I'm not taking any chances. Also, I'm exploring the possibility of including a light shield with the Harbinger Two. It really just depends on how quickly I can get up and running with the new 3d printer and if I can make enough in a week's time. We'll see. I know what the design is for the light shield but I don't know if I'm going to be proficient enough to do it in just a few days (esp. since I have not even assembled it)!
Reminder: the next batch will also include a free Snack Shack (DAM Meathead) board with all orders. I have plenty enough of these so they should be available for a couple of weeks. The PCB came out amazeballs.
I own madbeanpedals (duh). I am part owner of Function F(X).
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
Re: Releases pushed back to Jan 14th
« Reply #1 on: January 04, 2019, 07:07:11 PM »
PS I've put the following back in stock since there is no reason to wait: Aquaboy, the two 3PDT boards and all the VFE stuff.
However, the free SnackShack PCB will not be included until the new releases come out on the 14th, so keep that in mind.
  • Electron Doctor
  • Stephan Nelson / New Zealand / Aotearoa
    • View Profile
« Reply #2 on: January 04, 2019, 07:14:42 PM »
Awesome, I'm pumped for the Harbinger II (that is going in a wah shell, right?) as I have a shell already waiting and longing for it here!
Also me thinks I need a headtrip.
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
« Reply #3 on: January 04, 2019, 07:55:40 PM »
Yes, it is for a wah shell. It's mostly the same circuit as the Harbinger One with two exceptions: the rate control is totally different since it uses an ICAR pot AND there is an extra (optional) feature called "Drag". When the Drag is engaged the LFO rate ramps down when you go toe to heel....kind of like a delayed effect between fast and slow speeds. It's really musical and cool sounding. Also, the HB2 will include the required on-board slide switch to go between Vintage and Modern modes and a BS250p transistor used in the power supply section.
  • Electron Doctor
    • View Profile
« Reply #4 on: January 04, 2019, 07:58:50 PM »
That sounds spiffin'!
Also curious to see how you solved the speed pot there anyway getting it to work from the dual C100K to single pot.
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
« Reply #5 on: January 04, 2019, 08:07:20 PM »
It's similar to RG Keens UVIAWS but I did make some modifications to the circuit to suit my tastes. It uses two NSL32 optos with a transistor driver for the LEDs.
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
« Reply #6 on: January 07, 2019, 06:05:56 PM »
Update: I'll also be including the lamp for the Harbinger Two.
  • Electron Doctor
    • View Profile
« Reply #7 on: January 07, 2019, 08:05:02 PM »
It's getting better by the minute...  :)
  • Electron Doctor
  • Corey - Christchurch, NZ
    • View Profile
    • Soundcloud
« Reply #8 on: January 13, 2019, 02:45:53 AM »
Sweet idea for a business card right there Brian... just sayin 8)
cajone5
  • Electron Doctor
    • View Profile
« Reply #9 on: January 13, 2019, 01:46:49 PM »
In for Harb2
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
« Reply #10 on: January 14, 2019, 06:59:35 PM »
So obviously the new releases are not new releasing today. I hit a major roadblock with my Glitchee verification build and a minor one with the HB2 (that one appears to be builder error which I think I sorted out today). I'm not sure what's going on with the Glitchee because that circuit (well both of them) have been prototyped, vetted, breadboarded to death. Actually, I got so pissed off about the whole thing on Friday I took two days off which put me even further behind.
Anyway, it's looking more like Wednesday. If I can't get the Glitchee sorted by then I'll cut bait and get the other stuff released. I really hope that doesn't happen b/c when the Glitchee works it sounds absolutely badass.
  • Electron Doctor
  • Jimi Lee
    • View Profile
« Reply #11 on: January 14, 2019, 07:43:46 PM »
So, what you’re saying is there is a glitch in the glitchee?
  • Stompbox Star
    • View Profile
« Reply #12 on: January 14, 2019, 11:51:22 PM »
A little salt for those wounds.
Hahhaha
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
« Reply #13 on: January 15, 2019, 05:31:37 PM »
I'll remember your little jab, Jimi.
 8)
HB2 - much success. So univibe!
  • Electron Doctor
  • Jimi Lee
    • View Profile
« Reply #14 on: January 15, 2019, 07:20:19 PM »
Well....ok, you got me :P
