Author Topic: Help with switch tops.  (Read 400 times)
bscur
  • Transistor Tickler
    • View Profile
« on: January 06, 2019, 02:27:51 PM »
Hi,
I have destroyed a couple of these now and could use some help. The switches arrive with the straight shaft that has a channel in the side, like in the pic, but the diagram of the same switch shows it should have a threaded top. How do you get the cover off the top to reveal the threaded portion? I tried a wrench, but the whole top just rips off.
  • Electron Doctor
  • Matt
    • View Profile
    • My pedal blog
Re: Help with switch tops.
« Reply #1 on: January 06, 2019, 03:21:18 PM »
Are you sure that there is a threaded bit underneath?  Maybe their diagram is just wrong.  Wouldn't be the first time I've seem bad documentation.
Which doesn't really help with your question... Sorry.  :-\
  • Electron Doctor
  • Hamilton ON
    • View Profile
« Reply #2 on: January 06, 2019, 03:58:49 PM »
That's an unthreaded bushing, what's the part # you ordered, either you were sent the wrong one or the part number was wrong.
  • Electron Doctor
  • Dinner at Dorsia? No problem...
    • View Profile
« Reply #3 on: January 06, 2019, 05:10:02 PM »
Yep! This right here ^^^
bscur
    • View Profile
« Reply #4 on: January 06, 2019, 05:20:43 PM »
Hi,
The part I was told was C&K 7411SYZQE. I am doing a mod on a G&L L2000 bass and need a threaded top on a 4PDT On/On/On switch. Any help would be great. I've blown about $80 buying the wrong switches so far.
Thanks again,
Brad
  • Electron Doctor
  • Hamilton ON
    • View Profile
« Reply #5 on: January 06, 2019, 05:52:31 PM »
Digikey shows that part number as a 3pdt 0n/0n/0n with a threaded bushing, so shouldn't look like the one you pictured.
https://www.digikey.ca/product-detail/en/c-k/7411SYZQE/CKN1139-ND/259893
  • Electron Doctor
  • Hamilton ON
    • View Profile
« Reply #6 on: January 06, 2019, 06:13:59 PM »
Not sure what sort of specs you need. May be others here.
https://lovemyswitches.com/taiway-4pdt-on-on-on-switch-solder-lug-short-shaft/
