Turbo charger
Started by cooder, January 20, 2019, 05:39:37 AM
Nice cleanish with a bit of grit and airy, transparent and all those unicorn tears sounding boost and drive.
What else to say? Made on a ProfPoopy pedalpcbdotcom 'Six String Singer' board (google any of those and you shall find...).
Acrylic faceplate over laser waterslide decal, relay bypass from 1776 effects (I'm running low Josh, order will need to come soon...).
Miscalculated the position of name a bit too close to stomp.... ah well... next time...
This is why it sounds 'airy (fairy)': look at all the empty space...  ;)
lrgaraujo
Nice build as always Stephan. For what it's worth, I kind of like the way the edge of the stomp floats over the text. I think it looks somehow correct. Probably because of the way the center of the graphic sits above it. I think you should say you did it on purpose.
