Leviathan help wiring
Started by eduardo_gj1, March 13, 2019, 10:51:27 PM
eduardo_gj1
Hello, I am new here, I would like to start by greeting all the diy colleagues and administrators of this page.
I have a problem, I did the leviathan pbc but now I have problems to connect the footswitch, I have no idea what the mod, G and P of the pcb are for and something else, the wiring diagram of the footswitch is normal so truebypass
lrgaraujo
Hi! Welcome to the (probably) greatest forum out there!
G pads are usually extra ground pads Brian includes in his board designs.
The mod pad is there in case you want to include a modulation board (if you're building the Leviathan without modulation, you can leave it unconnected)
I couldn't find the P pad you mentioned
To connect the footswitch, you must use I, O and L pads following the wiring guide: http://www.madbeanpedals.com/tutorials/downloads/MBP_FootswitchWiring.pdf
eduardo_gj1
thanks for your answer, and yes you right hahaha was my mistake, but now i now see how is supposed to be wired
