Enclosures with 100% Straight/Vertical Sides?
Started by FuzzMonkey, May 19, 2019, 01:50:46 PM
FuzzMonkey
Sorry if this has been asked before, but does anybody know of any readily available pedal enclosures i.e. 1590B/125B-style that have 100% straight/vertical sides?
You'd be looking at either extruded, folded, or machined enclosures to get those straight sides.  The 2% draft angle is a necessary feature of cast enclosures.
You will probably find some nice machined enclosures in 1590B sizes if you search for "box mod" enclosures.  That's a term that the DIY vaping people use.
FuzzMonkey
Quote from: EBK on May 19, 2019, 05:55:30 PM
Thanks for the tip.
Aentons
Quote from: FuzzMonkey on May 19, 2019, 06:40:10 PM
Thanks for the tip.
I'm curious what you'd be using them for? I had the idea of using hollow bolts to join multiple enclosures together for multi-effect type thing. Let us know what you find?
FuzzMonkey
Quote from: Aentons on May 20, 2019, 05:27:17 AM
Thanks for the tip.
Just plain old curiosity really. I did find these at ModBoxMaker:
http://www.modmaker.co.uk/Enclosures/ModMakerBox-Enclosures?limit=100
Pretty expensive but the idea of using magnets rather than screw seems interesting.
Quote from: FuzzMonkey on May 22, 2019, 12:39:59 AM
Useful for those folks who fill every spare milimeter of those cases with high capacity lithium cells. Don't want a stray screw thread shaving to pierce one of those bombs in your pocket
Thanks for the tip.
Cast aluminum boxes are relatively inexpensive to produce.  Extruded alum is almost always going to be more expensive.
The issue with most extruded boxes is that they are usually made as a long tube and chopped, so the panels are usually attach to both ends, not top/bottom like most pedals.
I never see extruded enclosures with a flat surface on top.
These are interesting
https://www.hawkusa.com/manufacturers/hammond-mfg/enclosures/chassis/1444-8?gclid=EAIaIQobChMIso329sSv4gIVUV8NCh3NsAEBEAQYBCABEgIbzPD_BwE
Not sure if they'd hold up to being stomped on.
Have you considered using sheet aluminum and building and shielding a wooden frame for it to sit in.
Aentons
Aentons
#10
Thes Bud boxes don't appear to be sloped
https://www.budind.com/view/Die+Cast+Aluminum+Enclosure/Econobox
Edit: Nevermind... Their customer support says "they do have a draft angle, only way to get out of the mold"
FuzzMonkey
Obviously the answer is to learn sand casting and make your own!
...that feasible, right?
I'd say look for bent-metal enclosures.
They won't be as strong as die-cast, mind you.
Any reason you want non-sloping sides?
These are sweet looking:
https://www.ebay.com/itm/Alpinetech-1590B-CNC-Milled-Aluminum-Enclosure-Box-Hidden-Magnet-Anodized/222881126100?hash=item33e4c016d4
Another benefit of machined aluminum over cast aluminum enclosures is that machined enclosures can be beautifully anodized.  Cast enclosures have irregular crystalization patterns, which would leave them splotchy looking.
I used a machined wooden enclosure for my theremin fuzz, but the website appears to be no more.  Very expensive, but fun to experiment with.
