Author Topic: Your suggestions on overdrives for mbp  (Read 4103 times)
  • Corey - Christchurch, NZ
    • Soundcloud
Re: Your suggestions on overdrives for mbp
« Reply #60 on: October 25, 2019, 05:27:51 PM »
I really like the Sparkplug! Nice sparkly harmonic detail. Only got kicked off my board recently by a real tube overdriver. (Blackstar HT Dual)
Aentons
  • Solder Ninja
« Reply #61 on: October 25, 2019, 05:37:35 PM »
I'd love to see an overdrive/distortion that is an expander (that is, the opposite of a compressor) into a clipping stage. Exaggerating playing dynamics could make for a really interactive and touch sensitive overdrive.
The EHX Graphic Fuzz has an expander section. It's more of an od/dist than a fuzz.
Quote
I'd also like to see an implementation of the AMZ "warp control". Something that would let you blend between symmetrical and asymmetrical clipping.
Some of the VFE stuff has "warp" type blending controls. The Alpha Dog and Scream among others let you warp the clipping type
Aleph Null
  • Solder Ninja
    • The Hard Problem
« Reply #62 on: October 28, 2019, 05:14:21 PM »
Thanks for the tip! I'll have to look into the Graphic Fuzz.
  • Administrator
  • Brian
    • madbeanpedals
« Reply #63 on: October 31, 2019, 05:10:27 AM »
This is just to get the ball rolling. Re-designs of existing projects in line with my current layout style and a couple new/old ones. Not sure if i want to do the Lunchbox (BE-OD) since it's a bit out of character for me, but maybe.
These layouts are designed with options as far as enclosures - 1590B with regular bypass and side jacks (hopefully-it'll be a squeeze!), 1590B2 or 125B with top jacks and room for the Softie bypass.
I'll probably shoot for 5 or 6 more after I go over the responses in the thread again. See what I can cook up for the peoples.
Tremster
« Reply #64 on: October 31, 2019, 06:03:28 AM »
The Sparkplug with all external pots, oh yes!!!!
Also: what's the CFH from the projects page? Your own design or based on something?
(Also, on a side note: how about shrinking your silicon Tonebender to 1590A size?)
  • Administrator
  • Brian
    • madbeanpedals
« Reply #65 on: October 31, 2019, 06:57:51 AM »
The CFH is a very hacky effort. It's just a static SHO with clipping diodes and a tone control. But, it sounds quite good so I'm going to do a run of them. Also, CFH stands for Crotch Fire Hurricane.
I could do a Tonebender in 1590A. I'll work that up.
  • Eric K.
« Reply #66 on: October 31, 2019, 07:00:42 AM »
;D
Not affiliated with Oatey, makers of the world's best and most delicious* low tar solder paste. Ask for Oatey -- It's the juiciest!
*Solder paste is not food.  If ingested, seek medical help promptly.
benny_profane
  • Solder Ninja
« Reply #67 on: October 31, 2019, 07:53:53 AM »
Definitely stoked for the top jack redesigns. Also, I thought that CFH was pretty self-explanatory. What else could that possibly stand for?
Tremster
« Reply #68 on: October 31, 2019, 08:31:07 AM »
Sounds cool. Would that be a 1590A Grease Gun?
  • Administrator
  • Brian
    • madbeanpedals
« Reply #69 on: November 01, 2019, 06:28:03 AM »
Here it do.
Tremster
« Reply #70 on: November 01, 2019, 07:51:01 AM »
Wow. That was quick.
I was asking about the Tonebender because I recently built a 2-in-1, Silicon Fuzz Face & your Silicon Tonebender, which I had never built before for some reason. And I love it! A lot of fuzzes are useless on the first 75% of the gain range, but this is great all along, dirty overdrive to full on fuzz, and so simple to build.
Good to have the smaller version, too. Thanks!
Willybomb
    • RockStarGuitar
« Reply #71 on: November 02, 2019, 05:30:48 AM »
Is that the mythical full blown Mysterioso Snr?
  • Administrator
  • Brian
    • madbeanpedals
« Reply #72 on: November 04, 2019, 08:51:41 AM »
Indeed it is. Still one of my favorites. I have a version I built into a 1590B as an homage to the original but this one is 125B and a whole lot easier to build.
So, here's what I'm doing for sure:
- Grease Gun 2 (already know what I want to do with it).
- Rump Roast 2 (that's the Carmen Ghia I did a few years ago). I'm thinking the original in a 1590A and maybe a tube version in a 125B. Should it be a submini or 12ax7? It might be possible to set it up for either tube, actually.
- I really like he idea of the Graphic Fuzz but holey balls, it's pretty intense part-wise. Still, I may tackle it.
- I also really like the idea of a digitally-switched OD with different parts/values like the two JHS ones. I'd say that is a very high maybe.
- Still working on the Night Train OD - it's populated and just needs a small debug.
I'll still come back to the "well" here as I work on other ideas. I'd like to get about 15-20 OD projects done and call it a day (I'm already up to 10 layouts completed). Honestly, working on these feels like a cakewalk compared to some of the other stuff I've been trying to pull off the last year or two.
Matmosphere
  • Matthew
« Reply #73 on: November 04, 2019, 09:15:45 AM »
That all sounds pretty awesome.
Would you do sliders on the graphic fuzz or just pots? Either way itíll be cool. One possible thing that might make it interesting is if you could have the EQ work independent of have a switch for the fuzz. That way it could be a 5 band eq as well. But donít know if that would work with the circuit
Aleph Null
  • Solder Ninja
    • The Hard Problem
« Reply #74 on: November 04, 2019, 10:51:35 AM »
If I may ask, why the sudden interest in dirt boxes? Is a lot of the VFE stuff going away making room for new inventory? Just curious.
