FV-1 Build Arduino Eagle
Started by Leetut, June 15, 2019, 06:21:42 PM
Leetut
Last minute decision to put a Catalinbread RAH infront of the FV-1
Pre-Amp knob is just a DPDT rotary 2 position switch to turn the RAH on or off
I etched the RAH from effectslayouts
Display uses an Arduino nano, both fixed to an etched board
with a 16 position rotary switch to select 16 algorithms from 2 eprom's
Square hole was just drilled and filed, the trick is to open the hole with a file gradually
I.e. keep away from the edge until the last minute!
Paint is champagne metallic from Wilco U.K.
Text is plastisol screen printed
Both baked in an oven at 160c for 15 minutes
I made the FV-1 board in Eagle, it doesn't need the crystal if using the clock circuit and vice versa
FV-1 Eagle files, Arduino code:
https://www.dropbox.com/s/y171s6ltfl4jnyp/Graviton.zip?dl=0
Impressive.
Any shot of the guts? :)
Leetut
DLW
Wow.  Very impressive, inside and out.
fair.child
Aristatertotle
Well I know what I'm voting on come BOTY time.
Yahoo67
O O
  0
I think i just jizzed my pants.... gimme 2 sec i'll go check !
Looks fantastic!
Did you cut the window rectangle yourself or get the boxed fabbed that way?
Wow, just wow. Love how the display shows you the name of the programm and tells you what the controls do.
fantastic build
Quote from: selfdestroyer on June 16, 2019, 01:43:48 AM
He did it himself with a file. it's in the OP
TGP39
I love this.  Beautiful inside and out.  I've been shying away from digital builds.  You have just persuaded me to start learning.   Thank you for consistently raising the bar on what a diy pedal can do.   So inspiring.
-Steve
Looks bad-ass! I'm going to dig through this project a bit. Thanks a lot for the share. You're a super-star :)
