Author Topic: Worth switching op amps on a Klon Klone?  (Read 444 times)
  • Electron Doctor
    • View Profile
    • Project Website
Re: Worth switching op amps on a Klon Klone?
« Reply #15 on: July 13, 2019, 07:54:27 PM »
Dogfish, what if you really DO hear something different?  Never hurts to try.  Seriously.  Small investment and klons are the stuff myths are made of, so gives you piece of mind either way.
dogfish
  • Diode Destroyer
    • View Profile
« Reply #16 on: July 13, 2019, 08:33:43 PM »
We shall see. I actually work at a bass shop and hear enough builds that I really can hear the subtlety of some wood combos. I heard an ash body, roasted maple neck, ebony fingerboard J the other day that was really unique. I didnít know exactly what it was when I started playing it but could hear the combo right away... it itís not op amps so we shall see.
  • Electron Doctor
    • View Profile
    • http://alanp.info/
« Reply #17 on: July 14, 2019, 01:54:05 AM »
Dogfish, keep an eye out for any Black Maire wood -- it's a New Zealand native that is hard enough for fretboards.
"Hot water, good dentishtry and shoft lavatory paper."
- Cohen the Barbarian, on what is greatest in life
dogfish
  • Diode Destroyer
    • View Profile
« Reply #18 on: July 14, 2019, 06:22:36 AM »
We did build a J5 with an Aussie red gum top recently:
https://www.sadowsky.com/product/8258-standard-5-string-j-bass/
  • Electron Doctor
    • View Profile
« Reply #19 on: July 14, 2019, 06:30:42 AM »
Nice! Well, let me know if you do pick up any New Zealand timber, then :)
Rimu is beautiful as furniture -- I have a cab for my JCM800 done in rimu. Totara has been used as flooring, as it's pretty tough. Kauri has also been used for flooring, but it's wasting the wood to do that. Matai was a very popular flooring material. Most of these are reclaimed timber these days -- you cannot cut down native trees without a really good reason.
Black Maire is apparently the only native NZ timber that can hold a machined thread, if that helps any. It's popular as firewood, as it takes a long time for a log to burn down, and gives off a lot of heat.
  • Electron Doctor
    • View Profile
« Reply #20 on: July 14, 2019, 03:08:53 PM »
I try not to let myself get dragged into component debates but ...
Your breakdown of op amps was very good.
The thing I've noticed on a regular basis is that when unbiased professionals run tests on "Hi-Fi" op amps, they always come to the same results:  the lowly NE5532 is by far the best cost to sound quality chip available. Nothing in it's price range can match it, and spending 10x the price of a 5532 does not get you 10x better results. As far as op amps in overdrive/distortion pedals, anything other than a 741, 1458, LM308, or 4558 is pretty much overkill and will give you less of what you want. IMHO, TL072's or better give you everything that people complain about in solid state equipment in the first place...sterile "perfect" clean sound. Yes, uber high quality op amps can be beneficial in a delay, chorus, or flanger pedal where you don't want to add any noise...but there's really no reason to go above and beyond the 5532 in those cases. And in many pedal designs, just throwing a 5532 in place of say a 4558 will often add more noise because it wasn't designed for a 5532 or burr-brown super chip.
✅ This message is from a trusted sender.
