Author Topic: MXR Distortion + part value needed  (Read 414 times)
vicfiveleven
  • Diode Destroyer
« on: July 21, 2019, 07:37:10 PM »
Hi, I donít know if this is the correct place to post this. Please inform me if Iím in the wrong section. Anyway Iím modding and fixing an mxr distortion+ rev d. Saw one burnt resistor just below the dc power jack. It is tagged as R9 in the pcb. Anybody know the value? I tried to test it with DMM but got no value and google provided schematics, but only up until R6. It kinda looks like a 1M value so I replaced, but now pedal wonít turn on. Here are some pictures.
Re: MXR Distortion + part value needed
« Reply #1 on: July 21, 2019, 10:12:48 PM »
Looks like Brown-Black-Black-Gold-Brown, or 10 ohm (1% tolerance). I'm guessing its used as filtering on the power rail.
Plugging a 1M in that spot (assuming I'm reading the board right) would limit the circuit to .01 milamps, not enough to power it.
You could probably put a 100ohm in there to get a similar filtering effect with a little more wiggle room before popping.
Currently digging up board pics to confirm that, but that's my current hypothesis.
vicfiveleven
  • Diode Destroyer
« Reply #2 on: July 22, 2019, 07:19:06 AM »
Thanks for the reply somnif.  I'll replace the 1M with 100 ohms when I get home. I suspect those two resistors have something to do with the 9v power since they are solder there with the jack.  Don't know why that resistor got burnt because the owner said he seldom uses the pedal and just keeps it in the shelf.
Will keep you posted after I replace r9. Thanks again.
« Reply #3 on: July 22, 2019, 07:43:39 AM »
Reading around it appears to be a not uncommon fault (finding several forum posts about the same issue). I know Madbean used to use a 10ohm filter resistor on some projects, and they would have a similar burnout fault on occasion, so upped it to 100ohm (or left it out entirely).
The smaller the resistance the more heat the thing is going to (try to) pump out. The circuit is dead simple, probably only draws ~5mA on its own, plus maybe 10-ish for the LED, but any number of things could briefly spike the power draw leading to that poor little component going poof.
100ohm will give you more wiggle room in that regard, while still retaining the power filtering duties the old R held.
    • Project Website
« Reply #4 on: July 22, 2019, 04:38:25 PM »
For some reason I just happen to have a green board Dist+ board kicking around and R9 is a 10R.
vicfiveleven
  • Diode Destroyer
« Reply #5 on: July 24, 2019, 07:06:48 AM »
Soldered 100R on r9 and it worked.  Thanks a lot!
