Author Topic: Homing Missile Build Doc?  (Read 388 times)
Vtguy22
  • Diode Destroyer
« on: August 13, 2019, 11:25:39 AM »
Hello,
  Does anyone happen to have a build doc for the homing missile?
Thanks,
Paul.
DLW
  • Stompbox Star
Re: Homing Missile Build Doc?
« Reply #1 on: August 13, 2019, 07:05:08 PM »
Unless somebody has a better suggestion, I would follow what is written on the board. The "pwr" components have been 100n MLCC 2.5mm capacitors on other VFE boards that I've built. I assume it is the same here.
Vtguy22
  • Diode Destroyer
« Reply #2 on: August 14, 2019, 04:14:51 AM »
Thanks, the power board is my bigger problem.  I'm not sure what diode it takes, and if it's a split rail.
« Reply #3 on: August 14, 2019, 04:35:54 AM »
Given the circuit is a mix of the Rocket and Focus, I would GUESS it uses the "charge pump" (aka split rail) setup on the switching board. The board has power rails to both the "V+" and "V-" connections, also suggesting this.
Can't find definite info either way. Peter's schematics are... sparse in details, so the files aren't that much use here unfortunately.
Aentons
  • Solder Ninja
« Reply #4 on: August 14, 2019, 11:08:10 AM »
In the download bundle, I think he put an asterisk next to the ones that require the charge pump
Edit: just veried that the Homing Missile does have the asterisk in the doc so it is required
« Last Edit: August 14, 2019, 11:10:20 AM by Aentons »
« Reply #5 on: August 14, 2019, 03:01:07 PM »
Ah ha, so he did. I completely missed that  :-[
