Looking for a custom enclosure
Started by jaybird, August 20, 2019, 06:12:08 AM
jaybird
Im new, so forgive me if this is posted in the wrong place
I'm currently building 2 aquababies and I'm struggling to find a 1590B enclosure with the correct layout for the pedal.  I emailed Brian and he said my best bet would be to ask the forum - so does anyone here do custom enclosures?  Or can you direct me to someone who does reasonably priced custom enclosures?
Thanks y'all!
Aleph Null
#1
If you can gain access to a hand drill, a step bit, a center punch, a printer, and some tape, you can drill your own. Otherwise, you might look at Mamotth or Pedal Parts Plus
Willybomb
As you're using wired pots, according to the current aquababy pdf on the projects page, it's be just as easy to get a pre drilled, prepainted 125b from Tayda.  They're for pedalpcb boards, but you can use them easy enough.
jaybird
Quote from: Willybomb on August 21, 2019, 01:50:55 AM
Thanks Willybomb!
