Author Topic: Removing enclosure painted design  (Read 479 times)
vicfiveleven
  • Diode Destroyer
« on: September 18, 2019, 11:37:08 PM »
Okay so I have an extra enclosure from a delay circuit that I modded and rehoused. This enclosure was powder coated to army green and then the manufacturer painted the labels and brand on it. I made a vero EHX Green Russian Muff PI circuit w/c will perfectly fit the enclosure, 3 knobs, 2 jacks, dc jack, footswitch. My question is, is it possible to just remove the painted label and design and not damage or take off the powder coat? Sanding here is a big nope. The powder coat finish is a matte army green and perfect for the Green Russian. What should I use? Paint remover? Acetone? Thank you in advance. 😊
Matmosphere
  • Matthew
Re: Removing enclosure painted design
« Reply #1 on: September 19, 2019, 02:21:01 AM »
No idea, but Iíd open it up and test different things on the powder coat on the inside of the lid. If It doesnít damage the powder coat then see if it will take off the design.
My hunch is acetone might work, but I donít really know
Matmosphere
  • Matthew
« Reply #2 on: September 19, 2019, 02:21:46 AM »
Acetone might also dull the powder coat so be careful.
  • Eric K.
« Reply #3 on: September 19, 2019, 03:52:17 AM »
I'd try alcohol before I'd try acetone.
Another thing to try would be some strong-adhesive tape.  You may be able to pull the labeling off with it.
« Last Edit: September 19, 2019, 04:29:54 AM by EBK »
Not affiliated with Oatey, makers of the world's best and most delicious* low tar solder paste. Ask for Oatey -- It's the juiciest!
*Solder paste is not food.  If ingested, seek medical help promptly.
Matmosphere
  • Matthew
« Reply #4 on: September 19, 2019, 05:03:36 AM »
Those are both better ideas than acetone.
DLW
  • Stompbox Star
« Reply #5 on: September 19, 2019, 05:34:10 AM »
Isopropyl will not harm the powder coat. I'd try that first.
Acetone will damage the powder coat finish - might not take it off completely, but it will certainly dull the finish.
vicfiveleven
  • Diode Destroyer
« Reply #6 on: September 19, 2019, 07:07:46 AM »
Isopropyl high % worked, although it took a while and left small blemishes w/c can be fixed through light sanding.  I tried acetone on the back cover and yes you are all correct, it messed up a small area I was wiping.  Thank you all for the advice. :)
