Ok, so I built the Man-o-War dx and calibrated it. Pretty straight forward. I have built the Total Recall and AQDX delays in the past, so this one came together pretty fast.
Here are some observations, please chime in if I'm way off:
When "tails" is the only thing going to the output, the indicator is off. I flipped it around, so indicator is on with tails only, and off when delay is going through. I don't know if I explained that well. Lol!
LVL trimpot has to be turned up, like a good 2/3 of the way up to get around unity gain. I also have T1 turned most of the way up so the repeats go on for a LONG time. I don't know if it's infinite repeats, but there are a lot of them! Nice thing about them is that the repeats remain fairly clean... Much cleaner than the repeats on the ABDX.
The MoW can go into oscillation but both T1 and LVL have to be turned all the way up.
I did use a 78L12 to give the MoW 12 volts regulated. All Electronics has a 12.5 volt DC adaptor for $3.50 which actually puts out 14.5 volts, so it's great with this setup.
I didn't have 1/8 watt resistors so I just used 1/4 watters and did the Japanese transistor radio trick to get them to fit. Lol!
I'm really thinking about using one MN3101 clock and just solder a wire from pin 2 to pin 2 and pin 6 to pin 6 of the BBD chips. Why, you may ask??? Because I'm cheap and I can use the second clock for something else!
Anyway, this is a great delay, the repeats are super clean but a very different delay than the ABDX. I like them both!
