Author Topic: How do I run two phasers parallel in one pedal  (Read 602 times)
Jay.lingelbach
  • Diode Destroyer
« on: November 18, 2019, 11:32:09 AM »
Iíd like to split the input signal from the guitar with this http://tagboardeffects.blogspot.com/2014/08/amz-2-channel-splitter.html?m=1
How do I put them back together? Iíve seen mixer layouts, but what if I just want to combine the signals without mixing? Is there an easy way to do this? I donít want pots for the mixer Iíve seen.
http://tagboardeffects.blogspot.com/2013/01/2-channel-mixer.html?m=0
Sent from my iPhone using Tapatalk Pro
WormBoy
  • Solder Ninja
  • TJ
Re: How do I run two phasers parallel in one pedal
« Reply #1 on: November 18, 2019, 01:34:55 PM »
Every phaser already has a splitter and a mixer, just like every chorus, flanger and delay  :). They are all relying on splitting the signal, processing one copy, and mixing it back with the other, unprocessed, copy. So, you can learn a lot from the schematics that are out there for all kinds of pedals. Any specific phaser circuit that you are thinking of?
Jay.lingelbach
  • Diode Destroyer
« Reply #2 on: November 18, 2019, 02:21:05 PM »
The smoothie that madbean sells Iíll have a look at the schematic. Though Iím pretty horrible at reading them.
WormBoy
  • Solder Ninja
  • TJ
« Reply #3 on: November 19, 2019, 02:28:01 AM »
You could use a splitter/mixer project from TH Customs as inspiration: http://diy.thcustom.com/download/re-verb-v4-0-de-bauanleitung/?wpdmdl=3230. It starts with a splitter: two parallel opamp buffers. However, the smoothie already has an input buffer (well, a booster, I guess). So, you could simply build two smoothies and tie their inputs together (or save yourself a few parts by using one input cap and one series resistor at the input).
The smoothie itself splits the signal after its input buffer, and mixes them back with two simple 10k resistors (R15 and R16). My guess is that you could do the same to combine the signal from two smoothies: add 10k series resistors at the output and tie them together. The is in line with the schematic from TH, with the blend pot replaced by fixed resistors.
This is where I would start, just to see if you like the sound of two parallel phasers. I have no idea what to expect, so please post some sound samples  ;D. If you donít like it, you can always try placing the two circuits in series. If you like the sound, you can always add more luxurious features for the mixing section, such as extra opamp buffers before mixing as in the TH example, or an inverting opamp mixer as for example used in MBís Moodring. That latter one seems like a nice option: nicely buffered output, and a simple option to make sure you can set it to unity gain.
  • Jimi Lee
« Reply #4 on: November 19, 2019, 07:44:29 AM »
https://www.pedalpcb.com/product/duophase/
Here is what you need, the duo phase.
WormBoy
  • Solder Ninja
  • TJ
« Reply #5 on: November 19, 2019, 08:28:46 AM »
Well, not entirely: the duophase is basically just two phasers. The only extra is the ability to use one LFO for both (in same or reverse sweep). You can run the two phasers separately or in series, but to run them in parallel, you still need to do a little bit more. Not sure if parallel phasing sounds nice, though ... have you ever tried that?
PMowdes2
  • Stompbox Star
  • DeadEndFX
« Reply #6 on: November 19, 2019, 08:29:49 AM »
DeadEndFX
  • Jimi Lee
« Reply #7 on: November 19, 2019, 08:43:47 AM »
I was thinking it had a parallel switch, I have not done that, no. Check out the flying pan on the BYOC website. Itís another phaser bit I donít remember if it it will do parallel. Iíve built literally every phaser known so far.
WormBoy
  • Solder Ninja
  • TJ
« Reply #8 on: November 19, 2019, 11:29:48 AM »
The MXR Phase 99 does two phasers in parallel, but only with stereo outputs (does not mix them together to mono). But I think it's way more fun to cobble something together from simpler building blocks, and then bend it to your will.
icecycle66
  • Angelo
    • Heavy Record
« Reply #9 on: November 19, 2019, 09:54:38 PM »
About halfway down in this thread, DutchMF posted a switch diagram pdf.
It worked for me.
It switches the two circuits between series and parallel.
http://www.madbeanpedals.com/forum/index.php?topic=7437.msg64010#msg64010
  • Stephan Nelson / New Zealand / Aotearoa
« Reply #10 on: November 20, 2019, 12:48:25 AM »
I did the parallel phaser thing with two mutron phasers in this box. Both phaser can be on or just one and the splitter / mixer allows for blending clean and phased signal. One attraction of this is for me as well that I can blend with expression pedal between the two phasers or seamlessly from clean to phaser sound.
http://www.madbeanpedals.com/forum/index.php?topic=27872.msg269844#msg269844
WormBoy
  • Solder Ninja
  • TJ
« Reply #11 on: November 20, 2019, 07:41:20 AM »
Wow!  :o That's pretty spectacular! And, blending two phasers in parallel, does it give a useful sound? Very different from just 1 phaser?
Jay.lingelbach
  • Diode Destroyer
« Reply #12 on: November 20, 2019, 01:56:49 PM »
You guys are great. Looks like I have some inspiration now. Iíll keep working through it and see what I come up with.
  • Jimi Lee
« Reply #13 on: November 20, 2019, 07:24:19 PM »
Man, if you create a PCB, Iím all over it.
« Reply #14 on: November 21, 2019, 05:52:16 PM »
I personally find it fun and useful and I also like to use just one phaser on and other off, so basically clean with a bit of phaser mixed in and then I can step on the footswitch of second phaser and have the full on sound of two phaser in different speeds for example. I like it, of course it's a matter of taste.
I designed the mixer boards myself based on this schematic and there is a board available from JMK pedals:
http://jmkpcbs.com/product/paralyzer/
