LM4562HA
Started by 9Lives, December 06, 2011, 11:56:21 AM
9Lives
does anyone have any experience with this chip? I found one and it's on it's way. So I'm thinkin I'm gonna try and fit it in to myOCD clone. Any cautions?
stecykmi
that's a pretty damn good opamp, that has similar specs to the OPA2145, often considered an "audiophile" opamp.
9Lives
well what can I do with it?? It won't work in ocd. And lil biotch gets hot as hell. I wish I could make a distortion w it.
check the data sheet and pin outs and if needs be work up a layout or vero?
stecykmi
it should have the same pin-out as any other opamp... unless there's something I'm missing, it should be a drop-in replacement for any other dual opamp used in audio.
i would check your wiring and soldering, you may have made an error.
