Road Rage Silkscreen
Started by madbean, December 09, 2011, 06:28:00 PM
An error in the silkscreen has been discovered on the Road Rage PCB. The +15v and +18v labels should be reversed! Please see the illustration below.
The project documentation has been revised accordingly. Sorry!
http://www.madbeanpedals.com/projects/RoadRage/docs/RoadRage.pdf
As always, check your voltage output from the charge pump and/or regulator before connecting it to an effect. Supplying too high of a voltage CAN damage parts in some cases.
dwstanford
I'm glad i checked before plugging in the dirtbag.  If youre building the dirtbag with 3005's, definitely check voltages before hooking it up for testing.  If you ruin your BBD's you're liable to also ruin your BVD's.   :)
