Author Topic: 1590A Drill Template  (Read 12721 times)
  • Administrator
  • Brian
    • madbeanpedals
« on: February 11, 2012, 06:51:18 PM »
This is as close to a CAD drawing that one needs for hand drilling, I think. I've used this on a couple of boxes now and it seems to be correctly scaled. It has position markers for several pot layouts on the front face depending on what you are building. The scaled template is in the pdf file.
  • Josh
    • 1776 effects
Re: 1590A Drill Template
« Reply #1 on: February 12, 2012, 11:20:20 AM »
Fabulous!  I hate "eyeballing it" when drilling out the 1590A's.
Josh
jonrhee
  • Transistor Tickler
« Reply #2 on: February 12, 2012, 01:35:56 PM »
This is great!
Om_Audio
  • Solder Ninja
  • Clifford
« Reply #3 on: November 05, 2012, 01:11:45 AM »
Thanks!
C
Rethfing
  • Diode Destroyer
« Reply #4 on: February 02, 2013, 03:47:01 PM »
Are those drill holes for in and out jacks are ok for these open ones? Like this one?
http://www.superdyskoteka.pl/product/image/7090/1_2f50218740dc.jpg
Stomptown
  • Jon
« Reply #5 on: February 17, 2013, 12:23:35 PM »
I would read this guide that Madbean put out for projects using 1590A enclosures. It is super helpful for these builds.
http://madbeanpedals.com/downloads/BabyBoardGuide.pdf
It has links to mono jacks that work well in 1590A's. Using standard 1/4" jacks can work with some projects depending on the size of the PCB but the drill template he supplied may or may not work with standard jacks. If you do end up using standard jacks double check the drill spots and and that you will have room for your PCB (i don't think enclosure is deep enough to have board and standard jacks overlap). I have seen some people bend a terminal on the output jack to squeeze it closer to the 3PDT thus making more room for the PCB.
hgriffin1
  • Diode Destroyer
« Reply #6 on: February 09, 2014, 04:49:14 PM »
I get good results using graph paper. It's easy to align and offers great flexibility with the layout.
