Author Topic: How is babby formed?  (Read 10988 times)
Om_Audio
  • Solder Ninja
  • Clifford
Re: How is babby formed?
« Reply #30 on: February 14, 2012, 03:10:12 PM »
Ya Brian sounds like a good idea. I know w audio cable they say to try and cross them (on stage etc.) at 90 degrees if they have to cross- maybe in such smaller scale it is not an issue.
C
djaaz
  • Solder Ninja
« Reply #31 on: February 14, 2012, 03:49:26 PM »
Part of the idea here is not just 1590As (as Jacob points out they aren't for everyone) but also the ability to build a little custom multifx box. You could throw three in a 1590BB for an easy grab and go jam, or whatever. But yeah, use em to whatever suits your needs best, I say!
Yes, that's what is the most interesting about them size.
I was thinking of using a single footswitches but use somehow "switched" pots just like in the good old day.
In that spirit, it could be easy to add some "buit'in" modulation to a standard sized pedal. For instance add a chorus to the lowrider.
azrael
  • Diode Destroyer
« Reply #32 on: February 14, 2012, 04:12:09 PM »
i am excite for the new stuff.
DutchMF
« Reply #33 on: February 15, 2012, 11:37:48 AM »
Now that is freakin' good idea! I was still wondering if I could get my clumsy hands and size 12 feet around those Baby Boards, but fitting them in a large enclosure with an extra footswitch might work. I could also use standard size components (1/4 watt resistors & normal caps) which I have already....... Options, options!
To much fun ideas and to little time/funds, damn!
Paul
« Last Edit: February 15, 2012, 02:11:25 PM by DutchMF »
aziltz
  • Solder Ninja
« Reply #34 on: February 15, 2012, 11:49:43 AM »
will any of these baby boards have board mount pots?
  • Administrator
  • Brian
    • madbeanpedals
« Reply #35 on: February 15, 2012, 12:16:18 PM »
Nope.
djaaz
  • Solder Ninja
« Reply #36 on: February 15, 2012, 05:12:12 PM »
[ but fitting them in a large enclosure with an extra footswitch might work. I could also use standard size components (1/4 watt resistors & normal caps) which I have already....... Options, options!
Paul
I was thinking about something like a push/push pot:
http://www2.mouser.com/ProductDetail/Lorlin/MDSP5832/?qs=sGAEpiMZZMvmogu7fABzFuadJy78X803
or like this:
lloyd17
  • Transistor Tickler
« Reply #37 on: February 15, 2012, 10:07:49 PM »
wonder if I can cram a fuzz face, p45 and urchin into a landscape 1590bb. definitely going to try!
  • Josh
    • 1776 effects
« Reply #38 on: February 16, 2012, 06:29:45 AM »
I've got a 1590DD set aside for a multi fx grab and go  ;)
I'm with Jacob on the pedalboard usability.  I like stuffing things into a 1590A because it's a fun challenge but I find the enclosure harder to step on because it's not as stable because of the lack of Velco surface area.  But...it would be fun to have an all mini board anyways.  Especially with the new mini polytuner TC electronic came out with.  That would look so cool.
Josh
  • Administrator
  • Brian
    • madbeanpedals
« Reply #39 on: February 16, 2012, 07:18:39 AM »
lloyd - yes, I think that would fit.
Josh- I will be writing a general build guide specifically for the baby boards that shows exactly what hardware to use and how to lay it out in the 1590A for the easiest assembly. With a drill template and following the guide, I think it will make them as easy to build as any other type of enclosure (so I says).
  • Josh
    • 1776 effects
« Reply #40 on: February 16, 2012, 08:22:31 AM »
That's cool.  That will be really helpful with the "tight squeeze"!
I just have a hard time stepping on those little guys.  ;D
  • Administrator
  • Brian
    • madbeanpedals
« Reply #41 on: February 16, 2012, 08:39:41 AM »
Next project: Stompie 2000: The Pedal Stomping Robot Assistant.
  • Josh
    • 1776 effects
« Reply #42 on: February 16, 2012, 09:41:59 AM »
I'm in  ;)
jtn191
  • Jeff
    • Big Dipper Effects
« Reply #43 on: February 16, 2012, 11:58:46 AM »
that's really cool. sometime's even in a 1590B I have poor planing and barely scrape past a DC jack. And 1590as are so much riskier
Willybomb
    • RockStarGuitar
« Reply #44 on: February 16, 2012, 03:37:45 PM »
For me the enclosure size is about ergonomics - I don't want to be standing on multiple footswitches or hitting knobs when trying to turn a pedal on/off.  Even if I try these baby boards, I'd probably be putting it in a 1590B or something similar as a minimum.  Even the Crankosaurus I have to finish is going in a BB.
After all that though, a multi sounds like a lot of fun.
