Okay, I done goofed. An error in the output section of the Sunking was pointed out to me by a fellow FSB member. Luckily, it is pretty minor and an easy fix. There are three resistors that need to be removed from the board, and put on the switch. Also, two wires will need to be moved to different pads due to the missing resistors. Attached below is a diagram on how to make the correction.
My sincere apologies on this oversight. While it is not a huge mistake, it is one that escaped me for some time, nonetheless. I have not compared the corrected version to the original, but I am currently finishing up the prototype for the revised Sunking board, so hopefully I can provide some insight on whether or not there is any difference, tone-wise.
Corrected project doc:
http://www.madbeanpedals.com/projects/Sunking/docs/Sunking_D_ver2.pdfDiagram:
[attachment deleted by admin]
