03.18 - PreOrders are available
Started by madbean, March 18, 2012, 03:42:10 PM
ramengo
hi madbean... sorry for the stupid questions...can i  insert the switch in the rat for change the clipping mode?
i will buy this http://www.madbeanpedals.com/projects/Runt/Runt.pdf
and olso...if i don't do in this layout, can i remove the pot sweep of this progect?
http://www.madbeanpedals.com/projects/SlowLoris/docs/SlowLoris.pdf
Ramengo,
You can do the diodes switching on the Runt, but you are not going to be able to fit it all in a 1590A enclosure, I'm afraid. You can remove the sweep pot on the Slow Loris by jumpering pads 1 and 2 for the Sweep pot on the PCB.
All the documentation for the new projects is now available, except for the Collosalus. I have added dimensions for the Baby Boards PCBs in each document, and I have also made notes in the Slow Loris doc repeating this: http://www.madbeanpedals.com/forum/index.php?topic=4362.0
To do: The Collosalus will take a bit of time to document, but I am attaching both the schematic and BOM to this post for anyone who wants to get their parts together. Also, I will be typing up the ordering guide for the Baby Board today and tomorrow, so I will let everyone know once that is online.
NOTE_ There is a 500k trimpot missing for the BOM. That is for the Clock (it's in the schematic).
marmaliser
Quote from: madbean on March 28, 2012, 06:21:14 AM
Thanks Bean:)
DutchMF
Thanks for posting the Collosalus BOM, Brian, that's just what I needed! I'm gonna get my parts-order sorted out and order some more boards when that's done. Damn, never thought doing this would be so addictive...... I love it!
Paul
For the Collosalus, I found 47pF worked best with the clock (most likely because of the clock buffer), but I do suggest having a 33pF and 22pF handy just in case.
DutchMF
I'll keep in mind to socket that capacitor! There's no dual IC layout (as in the porkbarrel and currentlover) for this one?
Paul
Quote from: DutchMF on March 28, 2012, 11:08:29 AM
Paul
No, this is MN3007 only.
mmm tasty!
I'm diggin the metal can IC as well!
Josh
night-B
May I ask where have you found these cool jacks (in out and also DC)? I've never seen some like these before...
Ah... so cool! Very impressive enclosure-packing... squeezed so much in there ;)
pryde
Just gorgeous  :o
I cant wait till the baby overdrive comes out (outlander). Any teaser info on what this pedal will consist of?
Haberdasher
collosalus going into a 1590bb or can it fit in 125?
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
night-B  - I'll have info on the parts and hardware used for the build  in this doc I'm working on (actually the build tutorial portion is done---just gotta get the links for the parts in there).
pryde  - The Outlander is going to be a sort-of combination of an OCD and Zen Drive, I think. I have high hopes for it but I haven't even breadboarded it yet  :P
Haberdasher  - The Collosalus requires a 1590BB.
thetrend77
Does the Runt use board mounted 9mm pots? Actually, do all the baby boards use them?
