Multicolor led weird sound
Started by 2tonewarrior, March 26, 2012, 07:15:27 PM
2tonewarrior
I´ve build a Serendipity. The sound is very good in general but when the multicolor led changes his color it sound a weird beep. Here is a video with the problem:
Sorry for the crappy quality, I only have my mobile to record.
The only thing i´ve changed regarding to the project is the orientation of the led (same problem as here http://www.madbeanpedals.com/forum/index.php?topic=55.0) and one capacitor from Film/Foil to ceramic (I don´t know if it is relevant)
BTW here is the led i´ve used: http://www.banzaimusic.com/LED-5mm-RGB-multicolor.html
Hope you can help me :)
k.rock!
#1
Add a 33uF electrolytic (or any other polarized cap) in parallel with the LED. I believe you need to put it in opposite polarity with respect to the LED. Like this:
                    LED
(long lead)   ---|>|----  (short lead)
                    cap
If it helps but u can still hear it, then increase the capacitance.
Here's a build report I did a long time ago with a color changing LED. You can see the cap across the LED.
http://www.madbeanpedals.com/forum/index.php?topic=1074.0
-K
God bless!
www.kalebromero.com
2tonewarrior
Quote from: k.rock! on March 26, 2012, 07:50:32 PM
                    LED
                    cap
-K
Thank you, I´ll try it tomorrow. Could I start with a higher value? I have some electrolithycs here in my house but no 33uf.
k.rock!
Yeah, I mean you can certainly start lower too. I only said 33uF cause that's the value that worked best for me.
-K
God bless!
www.kalebromero.com
2tonewarrior
#4
Sorry for the late reply, I´ve been busy.
Awesome results, thanks for the help! The first I´ve tried (220uf) completely eliminates the annoying sound, but I´ve got a doubt. Should I keep looking for the best capacitor value? I mean, does it affects the sound in some way? or if it just works doesn´t matter?
