Wiring problem on first MadBean Build
Started by SGJarrod, September 30, 2010, 09:17:30 PM
SGJarrod
So I just finished my first MadBean build. I did the MuddyBunny and it rocks.... But it does not work with a power supply..only a battery... I used the normal 9v dc jack from SmallBear and wired it center neg like I always do... When you plug in a cable from my Dunlop Power Brick it cuts of the battery but does not power the pedal... I just got done switching out the dc jack thinking it was defective but I got the same results.
I used the wiring on this link from General Guitar Gadgets...any advice or ideas?
http://www.generalguitargadgets.com/diagrams/switch_lo_3pdt_ig_dcjack.gif?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
Can you post a pic of the guts of your build? Maybe we can identify the problem that way.
Chances are it's a simple problem. It may be a faulty jack, or more likely, you've made a small mistake and it should be easy to fix. Tutorials for debugging are coming!!
Give us more info and someone should be able to help.
scdesigns
Have you perhaps got the battery's + lead on the wrong lug of the dc jack? Try swapping them around.
SGJarrod
ya I'm a tard.... I had the plus lead of the snap on the outer positive in the DC Jack and not the inner one...funny this is my sixth pedal build and I never knew that made a difference...guess I got lucky on the others   :o
thanx guys
