Author Topic: IC Insertion  (Read 24970 times)
Pvt. Parts
  • Transistor Tickler
  • Guillermo
Re: IC Insertion
« Reply #15 on: November 20, 2012, 02:55:21 PM »
I just beat the crap out of it till it fits, but with care   :-*
"Do what you can with what you have where you are" T. Roosevelt
  • Jason - Evergreen State
Re: IC Insertion
« Reply #16 on: November 21, 2012, 02:21:49 PM »
I'm a big believer in the IC straightener now. Love mine. It's cheap and makes like sooooo much easier.
  • skilled electronics ninja master
  • Cody - Fresno CA USA
    • My Blog
Re: IC Insertion
« Reply #17 on: March 20, 2013, 09:29:38 PM »
Here's a cheap one from Jameco if you actually wanted to buy a tool.
IC Straightener
Ian
I had no idea they made a tool for that. I just place one side in the socket and then use a retractable blade to push the remainder pins until they fall into place.
  • Jimi Lee
Re: IC Insertion
« Reply #18 on: March 20, 2013, 10:08:44 PM »
I combine answers 1 and 2,not on purpose,just kind of winds up that way. ;D
fendman
  • Solder Ninja
  • Mike
Re: IC Insertion
« Reply #19 on: April 01, 2013, 10:08:41 AM »
Going back a few years, when I got these ic's. The packaging was great all you had to do was place it over the socket and push from the top...job done.
My it was good in those days ;D
aballen
Re: IC Insertion
« Reply #20 on: May 30, 2013, 01:26:02 PM »
This is the way to do it.
I hold the chip on its side so one set of legs is flat on a table top. I then carefully press down until the legs are more at a right angle to the chip body. I then flip it over and do the same to the other side. This works especially well for the 14 and 16 pin chips.
gingataff
  • Solder Ninja
Re: IC Insertion
« Reply #21 on: June 02, 2013, 03:55:40 AM »
When I'm not doing this...
I do this...
I usually put in one row a very small bit so that the IC is at an angle, then push all the pins of the other side at the same time with my tweezers until they pop in. Then push down the entire IC
Paul
but with my fingernails/tips...probably not 'best practice'  ;D
Thomas_H
    • DIY-TH custom effects
Re: IC Insertion
« Reply #22 on: June 04, 2013, 12:49:46 AM »
A few month ago I received a set of ICs from the supplier in these plastic covers and I thought: What a waste of space and so "ungreen". Now I know at least what it is supposed to do.
As I come from the digital side and started repairing Commodore 64 a few decades ago :-) I usually bend them in the socket. So you just put one side of pins  against the small socket wall and start applying pressure with your thumb from the other side until the pins have given just so much way that you can easily press it into the socket on both sides. Sometimes this requires to be done from both sides first depending on how sturdy this thing is. It requires some training though.
DIY-PCBs and projects:
rullywowr
  • Ben @ www.rullywow.com
    • Rullywow Industries - PCB's, DIY projects, and more!
Re: IC Insertion
« Reply #23 on: September 25, 2013, 10:02:02 AM »
I am a big fan of the tabletop method as well.  I can't see needing a tool to do this when it takes literally 5 seconds on any flat surface.  And I have never had a problem with the Tayda "cheap-o" DIP sockets for 8, 10, 16, 20, 28 pins for any pedal/MCU projects.  In a way I prefer them over the "SIP" style round sockets.
billstein
Re: IC Insertion
« Reply #24 on: September 25, 2013, 01:16:39 PM »
I like those cheap Tayda sockets too. Really easy to insert an IC into them and I've never had any problems with them either.
RobA
    • Music Unfolding
Re: IC Insertion
« Reply #25 on: September 25, 2013, 01:44:47 PM »
I use the cheap sockets if there is a reasonable likelihood that I'll remove the IC after it's in. If I plan on it being mostly permanent, I prefer the machined type. Also, I think the cheap sockets work better for anything that isn't plated holes.
kgull
  • Stompbox Star
  • Kyle
Re: IC Insertion
« Reply #26 on: March 10, 2015, 03:17:03 PM »
Bit of an older thread but I just finished up a pedal and thought I'd share my method.
Here's the IC before and after straighting:
I use a cheap pair of calipers to straighten the legs. They let me put even pressure on all the legs at once and I've yet to completely bork an IC as I do from time to time with the tabletop method.
Just pop the IC between the jaws and squeeze til the legs stay at ~0.3" on their own.
Slides right in no problem!
CodeMonk
  • Diode Destroyer
  • Personal Text Goes Here
Re: IC Insertion
« Reply #27 on: April 04, 2015, 04:37:18 AM »
I got one of these:
On the right side obviously.
It was only about $5 I think.
If you hurry, you might still be able to get one.
Amazon has a selection:
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=IC+insertion+tool
Off topic, but on the left is a cap tester I built from a kit:
http://www.amazon.com/Jyetech-Capacitance-Meter-DIY-KIT/dp/B00C5TRI3Q
My friends call me Rob
Affiliations :
Dalton Jones Electronics: Chief Tinkerer (Temporarily on hold)
SmallBear Electronics
GrindCustoms
  • Electrons are'nt bullshit dependant.
Re: IC Insertion
« Reply #28 on: April 04, 2015, 07:01:33 AM »
I got one of these:
Does the IC solder pump works well?
I also have built one of those capacitance meter a while ago, works quite well, much usefull with tropical caps...
PCB Projects: www.grindcustomsfx.com
www.facebook.com/GrindCustomsFX
www.facebook.com/InDefianceAudio
rullywowr
Re: IC Insertion
« Reply #29 on: April 04, 2015, 07:25:44 AM »
This is an old thread but I have gotten an IC leg straightener and love it.  Use it all the time.
