8 pin socket question
Started by spaceboss, May 31, 2012, 08:16:18 AM
spaceboss
For a build like the Dirtbag where the delay ICs only have 8 legs, would any harm come from snipping the unused socket legs in-between?
Thanks
SB
mgwhit
On the Dirtbag board it kinda looks like you would have to.  It certainly won't cause any problems with the socket.
DutchMF
What Timbo said! you can't have enough of that stuff around, IC's, transistors, diodes, anything you might ever wanna swap or is heat sensitive: SOCKETS!
Paul
spaceboss
If you prefer, you can also pop the pins out of the machined sockets instead of cutting them.
oldhousescott
Quote from: pickdropper on May 31, 2012, 11:26:18 AM
+1
This seems the best way, to me. Obviously not applicable with leaf spring contact sockets.
Actually, both the machine pin and leaf type pins can be popped out.
calciferspit
Quote from: jkokura on June 14, 2012, 11:21:37 AM
and then the machine pins can be used for individual sockets.
