Author Topic: Mudbunny/ Big muff Noise  (Read 4456 times)
SGJarrod
  • Diode Destroyer
« on: October 13, 2010, 08:51:48 PM »
So about a week ago I finished my Mudbunny and I must say this thing rocks and is mean.. I do have one issue.. The pedal operates and sounds perfect but when I have the pedal on and my guitar volume rolled off there is a weird scratching noise coming from the amp(it happens on both my amps), the more gain the more noise... now I do understand that muffs do have white noise but this is above the normal high gain noise. It sounds like an old record player between songs, you know the sound of the needle scratching thru the speaker. I just reflowed every drop of solder in the pedal and no difference.
I ran thru the board with a audio tester and it seems like the noise appears after the first set of diodes and gets worse after the 2nd set of diodes, it goes thru Q3 and Q4 all the way to the volume pot and then out. I tried new trannies out of curiosity and that did not help. All the parts are high quality new parts from Small Bear.
Anyone got advice or help? An idea?  ???
  • Administrator
  • Brian
    • madbeanpedals
Re: Mudbunny/ Big muff Noise
« Reply #1 on: October 14, 2010, 04:08:45 AM »
What kind of transistors did you use? When you replaced them, were the same type of trannies or different ones?
Also, what kind of diodes did you use in the build?
SGJarrod
  • Diode Destroyer
« Reply #2 on: October 14, 2010, 08:29:46 AM »
5089's both times, and I used the diodes that are recommended in the build...1n914, and 1n4001 for protection/polarity....
  • Administrator
  • Brian
    • madbeanpedals
« Reply #3 on: October 14, 2010, 09:29:22 AM »
I'm thinking that your input cap is leaky or faulty. That might explain the noise. If it's failing, then DC could be creeping back to your guitar, and when you roll the volume down it causes the crackling.
The noise might be originating there, and then it's amplified through those subsequent gain stages.
SGJarrod
  • Diode Destroyer
« Reply #4 on: October 14, 2010, 09:33:53 AM »
so, basically try a new cap in C1?
  • Administrator
  • Brian
    • madbeanpedals
« Reply #5 on: October 14, 2010, 10:13:45 AM »
Yep, I would try that first.
SGJarrod
  • Diode Destroyer
« Reply #6 on: October 14, 2010, 06:40:55 PM »
just got home from work and switched out C1 for a new cap and no difference, still have the same noise  ???
  • Administrator
  • Brian
    • madbeanpedals
« Reply #7 on: October 14, 2010, 06:58:38 PM »
Darn. Well, I think some voltage readings are needed. Maybe Q2 is misbiased somehow.
SGJarrod
  • Diode Destroyer
« Reply #8 on: October 14, 2010, 07:11:04 PM »
here is some more food for thought.... I just got done trying different trannies; 2n3904 and 2n5088 do not have the noise..... maybe the extra gain of the 2n5089's.....I actually really enjoyed the trying all the trannies....its the first time I have ever done that...... I love the 5089's the most, alot more aggressive and punchy...
any how... I do not have an operating multi meter right now so readings may have to wait....Does the info from above help or bring anything else to mind?
SGJarrod
  • Diode Destroyer
« Reply #9 on: October 14, 2010, 07:11:59 PM »
also I have already ran thru all the parts before I reflowed the solder and they are all correct
  • Administrator
  • Brian
    • madbeanpedals
« Reply #10 on: October 14, 2010, 09:07:37 PM »
Well, I don't have much advice at this point. If 5089's are causing the issue then for whatever reason they are not working for this build. Having built the Gruntbox a few times, I haven't had a problem. I can send you some 5809s to try out...maybe a different stock will produce different results. Personally, my favorites are BC549. I just love them in a Muff!
Tell you what: PM me your address and I can send you some of both. I have plenty. Let's see if that helps solve the issue.
SGJarrod
  • Diode Destroyer
« Reply #11 on: October 24, 2010, 05:25:14 PM »
Issue resolved... I got the BC549's and the 2n5089's that Bean sent me in the mail, neither of those had the noise....so, I guess the 5089's I had were from a bad stock  ???
I stuck with the BC549's, they were the quietest and had most clarity and punch......The MAYO is a GAIN MONSTER!!
Thanks MadBean... YOU ROCK!
  • Administrator
  • Brian
    • madbeanpedals
« Reply #12 on: October 24, 2010, 05:36:21 PM »
Excellent. Yep, BC549 are the best Muff transistors I've come across :)
Haberdasher
  • "El Duder-ino"
« Reply #13 on: October 24, 2010, 10:36:45 PM »
Brian- you use bc549B's?  The "B's" have kinda low gain; I tried them in mine and didn't like them as much as the 5089s.  About what hFe range do the ones you use have?  Or do you have the mouser link to them?
EDIT: These are the ones I ordered.  Are the ones you use different?
http://www.mouser.com/Search/ProductDetail.aspx?R=BC549Bvirtualkey51210000virtualkey512-BC549B
thanks
« Last Edit: October 25, 2010, 07:53:18 AM by Haberdasher »
FABRICATED PCB's FOR SALE:
  • Administrator
  • Brian
    • madbeanpedals
« Reply #14 on: October 25, 2010, 09:13:10 AM »
I have the "B"'. They do have "C" which are higher gain.
http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/BC549C/?qs=sGAEpiMZZMtvtNzZ3W%252bLwIHffn9J1%2fd6L7VProcj%2f2k%3d
I should pick some of those up on my next order.
