Author Topic: Dirtbag with 4xMN3008 (MN3005 fakes from smallbear)  (Read 5172 times)
RonaldB
  • Diode Destroyer
« on: June 06, 2012, 10:39:35 PM »
Hi,
After building the dirtbag with the V3205 chips I wasn't really happy with the sound.
So I purchased the MN3005 fakes from smallbear (2 sets). I made a little prefboard layout and changed the circuit to the MN3005 standard. Now the echo is beautifull.
What I did changed was for R11 and R12 39K instead of 68K. Somhow I liked it better with those values.
And after reading this post last night:
http://www.madbeanpedals.com/forum/index.php?topic=5090.0
I added a 100R resistor after C32. I will be trying a 1K potentiometer in the future.
Looks haven't changed, sound Oh yes. THANKS MADBEAN.
njkke
  • Stompbox Star
Re: Dirtbag with 4xMN3008 (MN3005 fakes from smallbear)
« Reply #1 on: June 07, 2012, 01:59:53 AM »
Can you tell me more about your mods? I've built a dirtbag with MN3205 that works one day at week! Probably the MN3205 from Hong Kong are instable in some way I don't know... I'd like to switch it to a MN3008 version, simplier to find in europe...
RonaldB
  • Diode Destroyer
« Reply #2 on: June 07, 2012, 04:47:04 AM »
I used the schematic Small bear added in his shop:
http://www.smallbearelec.com/servlet/Detail?no=247
And followed Madbean documentation to redo all the changes made for the V3205 version.
I'm also in europe (the Netherlands) to be exact. But ordering from Small Bear was easy and cheap.
Got them send in a week for 33 euro's.
best of luck
RonaldB
  • Josh
    • 1776 effects
« Reply #3 on: June 07, 2012, 05:07:12 AM »
Nice build.
Gut pics are required  ;D
Josh
the3secondrule
  • Jeremy - head solder monkey - tinnitus industries
    • My Band - Force Fields
« Reply #4 on: June 07, 2012, 06:02:22 AM »
What effect did/would this have?
cheers,
J
RonaldB
  • Diode Destroyer
« Reply #5 on: June 07, 2012, 06:23:24 AM »
They will follow  ;)
But because of the prefboard there is lots of spagetti in there (16 wires) ;D
RonaldB
  • Administrator
  • Brian
    • madbeanpedals
« Reply #6 on: June 07, 2012, 06:55:10 AM »
cheers,
J
It reduces the output of the compressor portion of the compander. IIRC, 39k is the value used on the Memory Boy which uses 4x BL3208a.
  • Lovetone 4 Ever
    • How Not To Make A Pedal
« Reply #7 on: June 07, 2012, 08:05:13 AM »
They will follow  ;)
RonaldB
please consider to post your doubledelay board layouts ? thanks
RonaldB
  • Diode Destroyer
« Reply #8 on: June 07, 2012, 11:41:38 AM »
Lacesensor:
I will draw one up tommorow. I did this one out of the top of my head.
Madbean:
I Think the 68K would work also but i'm happy with the 39K for now.
Will the dirtbag delay PCB's be stocked again soon?
RonaldB
sgmezei
  • Scott- AB, Canada
« Reply #9 on: June 07, 2012, 03:03:47 PM »
I would consider putting in a bypass switch. That way it isn't always on...... ;D
RonaldB
  • Diode Destroyer
« Reply #10 on: June 07, 2012, 10:40:09 PM »
i have all my effects routed through a bypass looper, no need for a switch in pedals then. ;D
RonaldB
  • Diode Destroyer
« Reply #11 on: June 08, 2012, 02:45:18 AM »
Here is the pref layout I would use the next time I will make these double delay boards.
Mine are a mess now but they work ;D
  • Lovetone 4 Ever
« Reply #12 on: June 08, 2012, 05:41:01 AM »
thanks
« Reply #13 on: June 08, 2012, 06:18:35 AM »
I think a layout that used PCB mount pin headers could clean up the wiring quite a lot.
After I finish up a few other things, I may make a go at it.
[EDIT] - Nevermind, I see that Smallbear has the PCB layout for this already on their site.
« Last Edit: June 08, 2012, 06:31:29 AM by pickdropper »
  • Lovetone 4 Ever
« Reply #14 on: June 08, 2012, 11:26:26 AM »
HI
This also works (at least in an aqua puss build)
http://www.sabrotone.com/?p=698
