Deadringer problems
Started by 2tonewarrior, August 31, 2012, 05:32:56 PM
mgwhit
Quote from: 2tonewarrior on September 03, 2012, 10:57:30 AM
I´ve checked the pots with the DMM and that was exactly the problem, a copper bridge I overlooked between 2 pads of the gain pot. I´ve checked all the board another time just in case.
Cool.  Glad you got that working!
I´ve encountered other minor problems. When the On-on-on switch is in the Vintage (Mosfet/silicon) the volume decreases. And I´m having the same issue with the boost (increases the volume a lot). Anyway the sound is good, only I have to pay more attention to the controls. I´m going to consider it done and going for another project. When I have time I come back to it and possibly etch a new PCB, I think most of this problems are caused by a bad etch.
The Boost should increase the volume (and the distortion) quite a bit  (especially since you used a 250K Gain pot).  And I agree with nzCdog about the volume change on the different clipping diodes.  That's typical.
2tonewarrior
I expected the boost to change the volume but in this case and in my opinion, the volume changes too much. Could be only myself and not a circuit problem. So if you two agree on the clipping I´m sure it´s working right. I´ll wait for nzCdog to compare voltages and verify.
ichilton
Hi,
Anyone with a working one able to post the voltages?
I've built one and it's not working either :(
Thanks,
Ian
