Author Topic: Working with tubes and recommended readings  (Read 2011 times)
2tonewarrior
  • Transistor Tickler
« on: September 13, 2012, 05:20:54 PM »
I started less than a year ago to make pedals. First some kits, then some brianīs boards, some veros,... Iīve made so far 10 or 11 pedals. Iīm very proud because I started from 0 at electronics. Iīve learned a lot, mostly in this forum reading a lot of tech help topics, but there are some things that canīt learn if I donīt study properly in a class, like safety measures. I would like to start working with tubes and maybe build some power supply so I ask for help understanding the danger of working with "high" voltages and how to work properly with them.
Also, I would like some recommendations readings (books, webs) to consolidate my electronics basics and learn more! (even better if related with pedals-amps) English is ok, I understand it better than I write it.
Thanks!
EDIT: For now I only want to work with tubes in pedals (valvecaster,..), not amps
« Last Edit: September 13, 2012, 05:32:49 PM by 2tonewarrior »
    • http://alanp.info/
Re: Working with tubes and recommended readings
« Reply #1 on: September 13, 2012, 05:32:08 PM »
One basic check is to test continuity or resistance between B+ and ground, or ground and anything that isn't supposed to be connected to ground. And to test connections with Mr Multimeter. And check that everything is where it should be, and not where it shouldn't.
Because if you think it's annoying when nine volt guitar pedals don't bloody work, you ain't seen nuthin'. It's very do-able, I'm just saying be methodical and check everything as you go.
"Hot water, good dentishtry and shoft lavatory paper."
- Cohen the Barbarian, on what is greatest in life
TNblueshawk
« Reply #2 on: September 18, 2012, 03:03:32 PM »
Here is a wealth of info to get rolling. It is mostly geared towards amps but...
http://www.buildyourownclone.com/board/viewtopic.php?f=49&t=34216
The guy that posted that is one of the local amp gurus we rely on at BYOC.
John
« Reply #3 on: September 18, 2012, 03:15:34 PM »
MetroAmp do not sell kits anymore, but if you are building a Marshall-style amp the instructions are worth their weight in gold --
http://metroamp.com/wiki/index.php/Category:Amp_Kit_Instructions
Highly detailed, lots of pictures.
2tonewarrior
« Reply #4 on: September 24, 2012, 05:42:59 PM »
Thanks for the tips, didnīt noticed the replays. Iīll check those links.
oldhousescott
  • Scott in SC
« Reply #5 on: September 25, 2012, 11:54:21 AM »
The NEETS manuals are good for learning about many aspects of electricity and electronics.
