egodriver help
Started by randel_07, November 22, 2010, 11:01:53 PM
randel_07
ok so basically i'm not getting any overdrive.
vol control works, tone control works. but even when the gain is all the way up, there is no overdrive
here's my pcb
there's that one cap that's sticking out, but i think it's not what's wrong
maysink
You sure you have the right cap values for C4 & C11? C11 looks to be in the power section of the circuit but C4 appears in the transistor/diode clipping section. At least I think that's clipping section...
[nothing to see here]
-e
randel_07
i have 1nF (102) for C4, and 100 nF (104) for C11
What kind of op-amp are you using? Did you use 2n7000's for the mosfets? Do you have a DMM so you can give us some voltages of the pins of the amp?
maysink
Yep, that's right! Do you have 4 pots in this build? Check all your solder joints and maybe try a different opamp. You can see the components in the drive section in the schematic--double check all them. Good luck!
-e
randel_07
I'm using a TL082CN op amp, and the readings are
1,2,3,5,6,7 = ~4.57V
4 = 0.04mV
8 = 9.14V
i'm using 2n7000's too
thanks for all the help btw. truly appreciate it
Based on those readings I'd put money on the pot being wired incorrectly. It looks to me like you're eiter running a dual volume or dual gain pot system with the 2nd 3PDT switch. Perhaps you should share exactly what's going on in your pedal and also give us the readings from the 2N7000s as well.
randel_07
o yea. basically, the other pot and 3pdt switch is for a SHO circuit
because i wanted a boost before the ocd. the SHO works fine, i just dunno why the ocd doesn't
Yeah, voltages are good, although I do wonder where that stray 4nV comes from.
You aren't going to want to hear this, but I don't think there is much you can do without first dissembling the board from the enclosure and working on it individually. If it were me, I would hook the board up to my testing rig without any switching to see if it is indeed working properly. If so, then you know it's a wiring problem in the enclosure. If not, then it is an actual problem with the build, which means you would have to remove it anyway.
Sucks, I know, but the process of elimination is sometimes the best route to take when debugging.
randel_07
haha yea i figured i had no choice so i started doing that already
but i have no more time, so i'm just gonna have to finish debugging when this semester ends
thank you for all the help
Sometimes a break from a pedal can be the cure. Let us know when you need more help.
